My eta wont rev past 3k. need help, soon
  • call me jack
    • Jul 2010
    • 425
    i'm not quite sure where to start. i test my coil, and tps and they both turned up good. i need some ideas though. i have a video on my phone that i will post when i got home, at about 330-4.
    I'm supposed to be selling this car, tonight, so this is kinda clutch!
    Edit: tested my AFM, as well for, continuty, and my fuel pump for current. tested o2 sensor. got no voltage response, at all
  • blunttech
    • 12850
    I have a spare afm to test if you want
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • call me jack
      • Jul 2010
      • 425
      i had good continuty in the the AFM as well... for got to mention that.
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        reference sensors? sticky throttle? cable out of adjustment?
        • call me jack
          • Jul 2010
          • 425
          i don't think its in the throttle... when it revs up that high the car starts to miss fire. based on a smoking rubber piece at the end of my tail pipe, i would say i have a hot exhaust, as well.
          • call me jack
            • Jul 2010
            • 425
            heres the video
            • lennon
              • Jun 2008
              • 1416
              did the problem just start out of nowhere?
              • spdracrm3
                • Sep 2009
                • 959
                plugged cat or exhaust system ? easy enough to drop header pipes to diagnose
                Angus
                88 E30M3 X2
                89 325IX
                92 R100GS/PD
                • daniel
                  • 6703
                  if you have an aftermarket chip that increases the rev limit to 7k, make sure you didn't put it in backwards. it can have the reverse effect and drop the redline down to 3k.
                  (i am kidding... please don't open up your ECU)
                  http://instagram.com/dslovn.drives
                  • McGyver
                    • 4637
                    ^so if i piggyback them i can get to 11k?
                    • ///digitalme
                      • Dec 2009
                      • 2088
                      is it in limp mode?
                      i say check your ecu...plugs, timing? crank position sensor?
                      • call me jack
                        • Jul 2010
                        • 425
                        yes. but i did replace my alternator the day before if it's of any consolation
                        could that really hinder performance that radically? i get 27mpg
                        Originally posted by ///digitalme
                        is it in limp mode?
                        today the rpm level dropped to 2k before it started doing this, so it doesn't sound like a limp mode. does this car even have a limp mode?
                        i did a load test on the fuel pump. 3.34 amps. thats well with in spec.
                        • call me jack
                          • Jul 2010
                          • 425
                          is there any way to test for a reference sensor?
                          • delatlanta1281
                            Dart Master
                            • Mar 2006
                            • 10317
                            Make sure you plugged your AFM in all the way.
                            Yours truly,
                            Rich
                            you kids get off my lawn.....
                            • call me jack
                              • Jul 2010
                              • 425
                              i just double checked. yeah, it's all the way in. i don't even know where to start at this point!
