i got a question for you guys
  • stewie30luvr
    • Nov 2008
    • 46
    i just bought a 98 bmw 528i and i have a big problem.
    1. When you turn off the car or even on the brake light from the drivers side is on and drops my battery dead.... i checked the brake switch and its good i disconneted it and still was on... any suggestions anyone.....
    Stewie30luvr!!!!!!!!!!:up::up:
  • Vince30
    • 2318
    Holy shit I had to read that like 8 times to figure out what you were trying to say
    Originally posted by stewie30luvr
    The drivers side brake light is always on even when the car is off, so its draining my battery on my 98 528i, I even disconnected my brake light switch and its still on. I know its not an e30 but I was wondering if anyone here can help me out.
    Fixed
    • reelizmpro
      • 9553
      Hate E39 electrical gremlins. From what I've read online. It can be the ignition switch or lamp control module. Check the lamp control module first. These are typical causes. You could always have a short somewhere also.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • dsobering47
        • Oct 2007
        • 697
        I'd almost say ignition switch before the light module...if the ignition switch supplies the voltage to enable the light module to turn on, wouldnt you start there?
        You can always just disconnect the switch and/or module and see if the light turns off...
        • stewie30luvr
          • Nov 2008
          • 46
          as you meant, it could be the ignition switch cuz my switch turns 360 degrees back like crazy i could go all day and it doesnt stop at all on less you go to the up position to turn the car on then it stops
          • stewie30luvr
            • Nov 2008
            • 46
            ill agree to the switch cuz like i said in the above quote^ the switch spins like crazy.... should it do that or not
            • reelizmpro
              • 9553
              There you go...try the switch then.
              88 M3 - LACHSSILBER
              • stewie30luvr
                • Nov 2008
                • 46
                thanxz guys for the help if anyone needs a break down of a car pm me i got mitchell 1 on demand. cars till 2009 any make and model
                • bimmerboy12
                  • Jun 2004
                  • 1057
                  make sure your turn signal isnt clicked down while the car is off?
                  1988 325iC Project - FINISHED!
                  Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
