The Tool Thread
  • grk325
    • 178
    The Tool Thread
    I dont know if it has been done in the past.
    Post compete tool sets that are worth purchasing.
    Perferably Mechanic Tool Sets.
    Ive been looking at what sears sells. way to many to chose from.
    looking at this Craftsman 266 pc. Mechanics Tool Set, SAE
    http://www.sears.com/sr/javasr/produ...id=00947971000
    other tools that i should look into.
  • Charlie
    kid tested, administrator approved
    • 6686
    Why would you go with SAE? If you're gonna work on BMW's, you'll at least want to go metric.
    Here's a start.
    This is the real way to go: http://www.ultimategarage.com/toolsb.html
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • rs4pro3
      • 5808
      Try to get as many 12 point sockets as possible as they make it less likely to strip a rusted bolt.
      85 325e 2.7 ITB'd stroker
      • grk325
        • 178
        $$$$$$$$$$$$$$$$$$$$$$$$$$i donT have that much cash yet. what would be the usual tools inorder to maintian my bimmer
        • Rob
          • 8166
          haha the tool thread, i thought this was about eurospeed or that kid from hawaii :P
          BEERTECH
          • Jand3rson
            • 37587
            No need to be an asshole Rob. Jeez.
            • rs4pro3
              • 5808
              Metric sockets from 6mm to 22mm are the most commom sizes you'll find, then open ended wrenchs in 7,8,10,11,12,13,17,19, thin 32mm Bicycle headset wrench. Good set of jackstands and a nice Floorjack. I have basically the exact sockets I need in my tool box If I have never used them on the bimmer I have tossed them in a box and stuck it in one of the drawers. Also I recomend getting some socket organizers, I used the foam cut out ones from sears and love it as it makes life easier so I don't have to dig for sockets. When I worked at a Junkyard stripping e30's they had tools but all the sockets where just tossed in the draws so I just ussed my own tools as I spent half the time hunting for the socket.
              • kidrobot
                Nekomata
                • 712
                Jesus, that setup is makin' me wet....
                Your parents should have beaten you as a child......
                「 Terror from the Rising Sun 」
                • chris_leo
                  • 63
                  HAHAHAHAHA. CLASSIC!
                  Thats what I was thinking too.
                  • BahnE30
                    • 1050
                    kidorbot
                    this is greathttp://www.maddox.xmission.com/beat.html
                    • UNHCLL
                      • 8790
                      What about kid from E3S who allegedly installed an M30, then sucked a valve or blew a piston and needed to know the right size spark plug?
                      We only use Snap-On.
                      Snap-On 0wnz everything else.
                      I should know, I got owned by a 13mm 3/8" ratchet/socket. Split my skull open! :roll: 8)
                      Below the radar...
                      • Rob
                        • 8166
                        or even better, the kid from e3s that dropped an e30 on his head then got mad when we called him out for being a dipshit
                        BEERTECH
                        • Spaz
                          Crazy Canuck
                          • 2276
                          actually you'll want 6-point sockets. 12 point are more likely to round a bolt. because a nut most of the time has 6 sides. so if you use a 12 point socket you are only grip on 1/2 of what a 6 point would.
                          just thought i'd clarify that.
                          -cam
                          Cam .W '91 325is
                          Spaz's 1991 Alpine White???? S52 Build Thread...
                            • 34844
                            I spent something like $500+ on tools last spring (never added it all up, but I was buying tools almost every day). I have just about everything now, although my spring compressor is a peice of crap. Anyone have a reccomondation on a decent spring compressor? Mine has a tendency to bind up and gouge the hell out of the springs, plus it can't fully compress the spring because of the way it attatches.
                            I also need a better torque wrench. Mine works fine for things like lug nuts, but my front hubs for example are torqued to 220ft-lbs, and my wrench only does 150.. I had to use a breaker bar with a big pipe to get it close enough after I maxed out my torque wrench.
                            • M-technik-3
                              • 18946
                              Twelve point is for Aviation hardware. Six point is for standard hardware, proper tool for the proper hardware.
                              Facom is = to Snap On it's just the French equilvent of it. Widely available in EU for good price. Griot's Garage is way over priced on there stuff. I just abought a unique 3/8" rachet set that has a hollow driver that you can put allen keys though to do your Struts and stuff like that for 38 bucks. It's Facom too. I do have a Lista tool cabinet the Gov't gave me and I have my own personal Snap On two piece roll away.
                              It looks like the one listed as #5 in the ultimate garage set up.
                              Used tools too are a great bargain when you can find a shop that sells them. There is a shop in Worcester Mass that specializes in them. The advertise in the want ad.
