Electric Fan Wiring Diagram
  • ZekeTheSneak
    • 1562
    So after many days of countless searching i only found bits and pieces on this subject. So today i spend an hour writing this up on Rhinoceros. Since there are many ways to wire in a fan please only helpful criticism. If you see anything that is wrong please let me know. Also the new spal fan will operate when the A/C button is depressed. This has not been tested but will be very shortly with eric's motor swap (avery0829). Any questions feel free to PM.
  • ZekeTheSneak
    • 1562
    disregard that part# just recieved mine it doesn't look right
    • ZekeTheSneak
      • 1562
      61318361787 correct part #
      • DaveSmed
        • Apr 2007
        • 1407
        A lot of that is unnecessary.
        Check this thread out, lots of good info.
        -Dave
        2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
        Need some help figuring out the ETM?
          • 34844
          the pelican instructions are pretty clear. that thread is full of confusion. switching the wires is not a big deal at all - just connect both sides of the switch to the high speed circuit. done.
          • ZekeTheSneak
            • 1562
            thanks nando, this is the way we did it with erics because he already had a relay for the spal so why not be extra safe, for mine I'm just using an 8 amp fan and using stock wiring with no relay. Forget paying 50 bucks for the fancy spal relay harness
              • 34844
              the stock wiring has a relay, two actually :p
