wet front passangers floor
  • RickSloan
    • 2401
    My right front floor mat has a wet spot from the carpet. Where is this water coming from? Bad door seals, window seals or somewhere else? There is no hole in the floor there but if i don't find the source soon there will be...
    any ideas?
    Need Illustration or Design work? www.robbiebyerly.com
  • Kershaw
    • 11822
    your elephant drain nozzle is clogged.
    look for a little black snout on the fire wall, approximately above your exhaust manifolds. pull it out. clean it. put it back in. or dont. w/e.
    AWD > RWD
    • KenC
      King of Kegstands
      • 14396
      Also possible that your rocker panel drains are crimped shut. There are three of them... just pry them open with a screwdriver.
      Originally posted by Gruelius
      • shiftbmw
        • Oct 2005
        • 2012
        This is my first guess. This drains the water from the space under the windshield wiper grills. Over time the plastic becomes brittle and debris(leaves, dirt) get trapped at the bottom. It's cheap and no big deal to replace, but a little dish soap can help make the install easier.
        "The best argument against democracy is a five-minute conversation with the average voter." - Winston Churchill
        • RickSloan
          • 2401
          thank you guys! I wouldn't have thought to look in either of those places. I will check them out tonight and see how it goes
