DIY Heaterbox
  • Dude
    • 1119
    #76
    found some good info for whatever route I choose
    • george graves
      • 19993
      #77
      more pictures
      Originally posted by Matt-B
      • kishg
        • Sep 2006
        • 2624
        #78
        that's one of several threads discussing how to keep defogging in race cars on the bf.c track section. jimmy has a somewhat better execution of your idea. keep in mind, these solutions are really mostly to provide defog, not really heat as you'd need in a street car on cold ne days like right now.
        '12 F30 328i Sport Line
        '91 SpecE30 #523
        '00 Ford F-350 Dually Tow Vehicle
        BMWCCA #360858 NASA #
        128290
        • jasonsnoddy
          • 1900
          #79
          i like seeing things like this. diy projects intrigue me.
          Originally posted by stewie30luvr
          ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
          Originally posted by JakeP
          with a coathanger
          • AwakenNoMore
            • Dec 2010
            • 1291
            #80
            Quite a few haters in here. IIRC the stock heater is expensive as hell. Props for making your own solution. Also you can probably get flexible hose from McMaster-Carr to route the heat for use as defrosters or vents and what not. Would be similar to some race cars.
            1991 325i - "Scambles" The Daily Driven lightly modded.
            1988 Mazda RX-7 TII "Mako" The Free Dorito
            bacon by Jared Laabs, on Flickr
            • 5Toes
              • 9836
              #81
              Why not do both OP? ROute the trans tunnel heat and run lines from your heater box.
              Just looking at the single pic, you're going to need insulation. Foam board would probably work best. Also, find some real fans, and figure out a way to put them on some real electric motors, RC car electric motors may do the trick?
              Like this cheap low power one: http://www.trossenrobotics.com/store...x?feed=Froogle
              It seems to draw 1A with no load. Your load will be small, so under 5amps I'd guess
              You need a resistor in line, because 12v will make that sucker scream
              • george graves
                • 19993
                #82
                Yea, dude. A whole $20.
                • franco90
                  • 3185
                  #83
                  Lol
                  I've always been proud of being a Marine.
                  I won't hesitate to defend the Corps
                  "Supersquad"
                  ‎"Prostitutes are a sub-category of Amusement Parks"-
                  • 10Toes
                    Me Father Was A Tree
                    • Jan 2008
                    • 61222
                    #84
                    I need more fish tank.
                    • Cabriolet
                      • 9620
                      #85
                      I need more cowbell in this thread
                      Much wow
                      I hate 4 doors
                      • Dude
                        • 1119
                        #86
                        Not a bad idea. I was trying to figure where I should pull air from, the cabin or the dead space where the blower motor usually is.
                        • george graves
                          • 19993
                          #87
                          Can I get a well lit picture looking into the front of the box? I have a suggestion - but need to draw it.
                          • Dude
                            • 1119
                            #88
                            • george graves
                              • 19993
                              #89
                              So far, all I can tell is that your google image search skills far exceeded your fabrication skills.
                              • Dude
                                • 1119
                                #90
                                Elaborate one whats been fabbed up poorly?
