Power mirrors...what could be wrong?
  • Bimmerfanatik
    • May 2004
    • 5349
    Checked the fuse, it's fine. #19, 7.5a.
    Checked the connection from the door to the mirror and to the switch - also fine.
    Can the switch be bad? Also, how can I check for constant at the switch? Which pin is the constant? Or maybe the mechanisms inside the mirrors themselves burned out?
  • Court M3
    • Jan 2004
    • 6713
    Mine are doing the same thing. Although last weekend while replacing the door pockets, they worked with the door panel off. :? As soon as I finished putting everything back together they stopped working again
    Continuous For Sale Thread
    323i s50
    • Bimmerfanatik
      • May 2004
      • 5349
      Where'd you get that snazzy door pocket? :)
      Let me know if you discover the problem. I tried without the panel on - no luck.
      Anyone have the constant pin on that plug?
        • 34835
        the switches stop working, the contacts get dirty. I took mine apart and cleaned it.
        • Bimmerfanatik
          • May 2004
          • 5349
          Ok, i've got like 6 of these things lying around and I know some of them work, I'll try swapping and see what happens.
          Also, it seems the mirror glass doesnt want to stay in one place for long - I'm constantly adjusting them, and that's hard with no switch :) Anyone have this problem?
          • PeterCip
            • 402
            Check the connector in the door pillar for corrosion.
