ratio brain fart
  • 3bvert
    • 1032
    ratio brain fart
    ok...tired
    playing with numbers
    what rear end ratio a ratio would give me lower engine rpms at say 60mph
    a ratio with a higher number ( say 3.36)
    or a ratio with a slightly lower number ( 3.2)
  • drumad
    • Aug 2009
    • 1700
    lower aka taller aka longer
    I think... unless I'm brain farting as well
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • 323iNathan
      • 232
      Well the eta's only rev to 5K and their diffs are around 2.9 - 2.7:1
      Therefore... ;)
      • 3bvert
        • 1032
        going for more economy, dont need to get faster to 60, just more fuel efficient
        so I guess the 3.2 in my example is the more efficient from what you two are saying
        • Special K
          • Jun 2010
          • 23
          A lower number in your rear end will give you lower rev's
          • Holland
            • Nov 2008
            • 7212
            Lower = Taller.
            Originally posted by DEV0 E30
            • 3bvert
              • 1032
              thanks guys
              I told you I was tired, and starting to second guess myself as someone was trying to convince me the other way around
              • CabbE30
                • Aug 2009
                • 2358
                4.10 LSD
                do it!
                • Conki
                  • 1254
                  Got 3.73 LSD in my eta, stupid fun!
                  It tops out around 120, but who needs to go faster than that anyway? haha
                  1992 BMW 525iT Calypso
                  2011 Jeep Wrangler
                  • woodisgood
                    • 1087
                    This calculator is designed to give you a rear end gear ratio.
                    • iamsam
                      • Jun 2008
                      • 174
                      its easy. a 4.10 diff means 1:4.1 ratio. That means for every revolution of your rear wheels, your driveshaft has spun around 4.1 times. Therefore, the smaller number (or bigger ratio, as the number is always divided by 1), the less times your driveshaft spins to make the wheels spin once.
