Do you know what this relay controls ?
  • Robert
    • Dec 2010
    • 3770
    Just figured out that the orange relay in this picture was unplugged & i plugged it back in . Now there is a hissing noise coming from near the thermostat , it sounds like a vacuum hose . Noise also coming from rear of vehicle .
  • woodisgood
    • 1087
    I think that one is for idle.....
    • James Crivellone
      Head Janitor
      • 6305
      Those are the main relay, fuel pump relay, and o2 sensor heater.
      • E30SPDFRK
        • 5709
        Fuel pump, the hissing is the fuel going throught the fuel pressure regulator.
        Byron
        Leichtbau
        • Robert
          • Dec 2010
          • 3770
          Thanks guys !
          The hissing isn't going away.. for now i just unplugged the relay ..
          Do you guys think its a bad fuel pressure regulator ?
          • Robert
            • Dec 2010
            • 3770
            Anyone know what the problem is ? )':
            Everytime i'm finish drivving the car , i need to unplug the relay because the fuel pump will just stay on if i dont.
            • dj01540i6sp
              • Jan 2009
              • 349
              Will the car run with out it? Sounds like the relay is stuck, take it apart and look at the contacts if they are closed/stuck pry them apart, get/try a different relay. If all is OK then something is giving it power to turn on. GL
              • Robert
                • Dec 2010
                • 3770
                Nope, the car starts w/o the relay , but turns off in a few seconds because theirs not fuel being pumped into the engine .
                Alright , I will take the relay apart and check the contacts tomorrow .
                If all that fails , i'll just buy a new fuel pump relay hopefully that's the problem.
                Thank you , I will let you know how it goes
                • techterr
                  • Jun 2007
                  • 91
                  had the same problem last week.. it turned out to be the main relay, the one on the left, that had fused the contacts... replaced the fuel pump relay and it kept doing the same thing, continuos running of the fuel pump.. changed out the main relay and all is well... Cracked open the main relay and found the contacts welded together... cheap german parts.. after only 26 years the damm thing went out...
                  • StereoInstaller1
                    GAS
                    • 22679
                    heh..."the damn thing is shot after only 300,000 miles!"
                    Closing SOON!
                    Thanks for 10 years of fun!
