Speed Sensor Plug/Wire
  • freeride53
    • 11972
    I just realized that my odometer, speedometer, and MPG meter are NOT working because of a fault in the speed sensor/plug/wire equation.
    How can I pinpoint this? Is the plug the rectangular one that is zip-tied down on the back off the diff cover? How can I tell where the problem is coming from?
    Thanks!
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • ZM Blue Devil
    • Dec 2006
    • 13836
    did you inspect it? Is the plug on there good? It could just be the sensor or the connection is bad.
    Levent
    %20levent@gutenparts.com
    Ladies:
    • freeride53
      • 11972
      About to check it out again, to make sure.
      Levent, which # Fuse is in charge of the speedometer/odometer/mpg meter?
      The tachometer works still..as does the fuel tank gauge.
        • 34844
        I don't think there is a fuese for the diff sensor
        definitely check the condition of the wires and connection, and check the sensor itself for cracks.
        • freeride53
          • 11972
          Thanks for the input guys.
          It turned out to be another short, caused by my previous cluster.
          • Zacm829
            • Jan 2008
            • 1919
            Where was the other short? I'm having a similar problem.
            1987 325i-M60b44 swap
            • imdashiz
              • Sep 2009
              • 1373
              +1 would like to know also
              PSN ID: Yourself1
              • durtyE30
                • 707
                +1, my speedometer stopped working but all the other gauges act fine.
                • freeride53
                  • 11972
                  sorry for taking so long guys. mine was in the cluster.
                  probably in the si board, after i replaced the cluster, the fuse stopped popping
                  • boosted_E30
                    • Dec 2010
                    • 173
                    What fuse are you talking about, that was popping?
