OEM eccentric RTAB's?
  • schtozo
    • 1455
    Ok i want to change my rear subframe and rtabs and saw on realoem two choices for the rtabs either regular or eccentric ones. Are the eccentric easy to deal with? I mean how much camber do they correct? And does insalation involve any major issues? Is it easy fr the person who will align the car later to play with them or are they a one time install and no going back?
    Dunno if you understand my questions ley me know...
    Easier: buy regular or eccentric RTAB's?
    One of the best threads you will ever read
    http://www.r3vlimited.com/board/showthread.php?t=221813
    Nice trailer of my e30
    http://www.youtube.com/watch?v=TTjtG...e_gdata_player
    If i sold you something please leave feedback here
    http://www.r3vlimited.com/board/showthread.php?t=217142
  • LJ851
    • 7918
    They are a one time deal and not a very big change. They are just a stock bushing with the inner steel sleeve offset in the rubber.After you remove your RTABs you will understand why they are not adjustable post install !I think they give you like 1/2 a degree change max. You would need to mark your trailing arms as they sit at ride height so you could install them for max camber and toe change. make sense ? regular bushings are foolproof-ish so they would be easier.
    Lorin
    The M30 is God's engine.
    • nrubenstein
      • 3148
      The way you install the eccentrics is you START with good normal RTABs and throw the car on an alignment rack. Afterwards, you calculate an approximate change and install them. You can also use them to take out a little bit of camber if you know you are low.
      All in all, just go with the standard ones.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • LJ851
        • 7918
        I was going on the assumption that everyone here is low enough that max camber and toe removal will still not be enough...
        Lorin
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          If you're more than 0.5* off your desired camber or toe setting in the rear, these will not be enough to correct your problem. You'll need a weld-on adjustment kit such as the one Ireland Engineering sells, paired with OEM rubber bushings.
          • schtozo
            • 1455
            Yeah i thought the same thing, they are not worth it. Im at -3.20 rears with billy sport / IE3's.i guess ill go with the original one s and save $10 haha
              • 34839
              by far the simplest solution is to use shorter subframe bushings. AKG sells some that raise the subframe 12mm up into the car - that effectively takes out 1/2 degree out the the car.
              eccentric bushings should only be used if class rules require OEM parts, the problem is they don't hold adjustment very well and they change toe and camber at the same time, in addition to being restricted in their range of adjustment.
              • mikeedler
                • 6707
                I completely disagree. if it is only 10 dollars more and you are doing them anyway, why wouldnt you atleast help it a bit. plus your excessive camber also comes from worn out bushings too.
                • 325ix
                  • Aug 2009
                  • 7783
                  ^you make a very good point. That in combination wiht Nando's suggestion should put you at least decently close to a good setting.
                  • ZekeTheSneak
                    • 1562
                    Akgmotorsports.com sells adjustable ones. I do not know to what extent but another possibility.
                    • schtozo
                      • 1455
                      Yeah i looked at those, but the thing i dont wany poly bushings as they will make weird sounds then and the ride will be stiffer, am i correct? So probably oem will be my best bet and will last probably 20 years? Haha
                        • 34839
                        subframe bushings do not make noise, and if you don't go with a super high durometer it's not really a lot stiffer than the stock rubber bushings.
                        • schtozo
                          • 1455
                          Well i see 2 choices either the 75d or 80a. My choice should be 80a? And then some oem RTABs should make the job? By the way will you recommend me to get new bolts and nuts at least for the subframe bushings and reuse the rtabs old ones? I dont want any surprises and then have to leave the car a week till i can find new ones. So tell me what should i do? Sorry to ask so many stupid questions but i really dont have any experience with bushing changing and dunno what will be the condition of the mentioned bolts
                          • LJ851
                            • 7918
                            True , subframe bushes dont effect ride quality but remember your diff is bolted solid to the subframe and the harder your bushes are the more diff noise is transmitted into the chassis . BTW, none of these bushes are easy to replace . do you have access to a press ?Or know someone with the special tools ? You will be cursing your first time at this rodeo !
                            Lorin
                              • 34839
                              80a is the one to go with.
                              it's not going to make any difference to cabin noise. Maybe 75d, but I'd be surprised if you could even tell a difference with 80a bushings.
