Has anybody written one up? If so I can't find one, but then again I suck at searching. Have to switch mine over this weekend to make sure I can drive back and forth to work. Any help would be appreciated, thanks.
alternator DIY
Originally posted by Matt-B View Postloosen, remove 2 bolts and undo 2 wires.
reinstall? Its a 30 min job
Originally posted by Hick View Postremoved wallet from pocket.... hand creditcard to mechanic
Originally posted by mbulsa View Posthaha that's what i thought, i don't need to take off any other parts or anything right?
Originally posted by Matt-B View PostThe more you think about it, the less self confidence you will have, go change it and report back...
Originally posted by matias88e30 View PostMaybe this will help?
http://www.pelicanparts.com/bmw/tech...Alternator.htm
Thanks, I was on pelican for a while and just stumpled across that too
Once you see it, you'll know what to do since its not really that difficult. Just remember to disconnect the battery and tighten the belt. But if you wanna guide, you can download the manuals (http://www.r3vlimited.com/board/showthread.php?t=193176) and use that.
Originally posted by LagunengrunE36 View PostOnce you see it, you'll know what to do since its not really that difficult. Just remember to disconnect the battery and tighten the belt. But if you wanna guide, you can download the manuals (http://www.r3vlimited.com/board/showthread.php?t=193176) and use that.
