Locals? willing to help!
  • Dtmnuka
    • 124
    I was driving home last night and when I got home I noticed the car was over heating and smoking like crazy. I let it cool down over night and this morning I threw a new radiator in ran it and is still over heating. The upper radiator hose seems to be getting hot but the lower hose doesn't feel warm at all. Don't really know what this means... I NEED HELP
    Anyone local mind coming by and helping me figure this issue out?
    WOULD REALLY APPRECIATE IT!
    Dont worry Im not some 50 year old whos looking to tickle your butt! I just need help. hahaha
  • woodisgood
    • 1087
    check your thermostat.
    • grantlacey11
      • Jan 2009
      • 680
      thermostat
      • 5spoke
        • Sep 2007
        • 1729
        Don't do this anymore.
        • ReallyDirtyThirty
          • Jul 2010
          • 449
          Why did you change your radiator before your thermostat? How long did it overheat? How long did you run it overheated? Is the head gasket blown? Etc...
          www.truegearhead.com
          - bad decisions & questionable cars
          • Dtmnuka
            • 124
            It was over heating for like a few mins and I shut it down. I checked my oil and it didnt look milky so I don't think the head gasket is blown. I changed that first because I had that sitting in my garage and I thought it would be a good place to start. How do I check my thermostat?
            • slammin.e28
              שמע ישראל
              • 12054
              -Take it (thermostat) out of car.
              -Get a pot, thermometer, and a stove.
              -Fill pot with water.
              -Put on stove.
              -Turn stove on.
              -Put thermometer in pot.
              -Put thermostat in pot.
              -Check temp on thermometer when t-stat opens up.
              -Assuming you have the stock temp t-stat, it should open up around 80 degrees. There are ones for 71 and 75 degrees too. Sometimes they say on the t-stat.
              -Take action according to results.
              -Done.
              I do this even to new ones because they can be faulty new. AMHIK.
              • ReallyDirtyThirty
                • Jul 2010
                • 449
                Just as an FYI, thermostat is where you want to start first when things like this happen, unless there is literally a giant hole in your radiator or something like that.
                • e30lov
                  • Jul 2008
                  • 1597
                  cant believe nobody has mentioned this already...
                  `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
                  • Dtmnuka
                    • 124
                    Alright guys tomorrow Im pulling it out and testing it with the method mentioned above. anyone know of a write up on how to get it out...
                    • ReallyDirtyThirty
                      • Jul 2010
                      • 449
                      Search, "thermostat removal and replacement".
                      • Dtmnuka
                        • 124
                        Just tested the thermostat and Its working fine. It opened up and closed when I took it out of the water. :(
                        Where do I go from here fellas?
                        • Need4Speed1299
                          • Oct 2007
                          • 119
                          ROFL!
                          ...rendering, haha.
                          • ReallyDirtyThirty
                            • Jul 2010
                            • 449
                            Verify your waterpump is working and also check coolant temp sensor.
                            • Simon S
                              • Oct 2004
                              • 3758
                              Waterpump.
                              -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
