A couple inline six questions
  • Conki
    • 1254
    Yeah why does it have to be aluminium?
    If I understand correctly, you want to create a display engine, right?
    Is it going to be a cutaway? Then I understand you want a SOHC design for simplicity and clarity, but why is there a material requirement?
    And I6 engines are in perfect balance, yes, but if it's not going to run, why does it matter?
    And even if you plan to run it, any other engine would have low vibration with factory balancer.
    1992 BMW 525iT Calypso
    2011 Jeep Wrangler
    • SpecM
      • Oct 2005
      • 4531
      Originally posted by Conki
      You mean OHV.
      yes, and the Jeep 4.0 is a pushrod (OHV) engine anyway
      the cam is in the block, not head
      1989 cirrisblau-metallic 325i
      • Bimmerman325i
        • 6854
        Why aluminum? For an art project, the material doesn't seem like it should matter. Hell, spraypaint a $100 M20B27 block to look aluminum if it really matters.
        2017 Chevrolet SS, 6MT
        95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
        98 M3/4/5 (stock)
        • Fusion
          • Nov 2009
          • 3659
          Oh, I didn't notice the Jeep isn't SOHC.
          I was thinking it would be easier to work with the aluminium block if we wanted to do a cutaway on one of the cylinders or drill/thread parts if we need to, and the small weight difference.
          • Conki
            • 1254
            Aluminum engines are newer, so they tend to come with DOHC, so you've got a decision to make here.
            2011 Jeep Wrangler
            • tjts1
              • May 2007
              • 1851
              The solution is simple. BMW M70. V12 (2 inline sixes), Alloy block, SOHC, dirt cheap. Lose all the ancilary BS, and cut away. Would make a hell of an art project.
              • Danny
                • 14216
                ^Not a bad idea.
                You can find them pretty cheap too.
                • bimmerfan46
                  • 15
                  That would work well because you could leave one side intact and do a cutaway on the other.
                  Originally posted by RainierHooker
                  There's only two things I hate in this world. People who are intolerant of other people's cultures and the Dutch.
                  • e34john
                    • Apr 2006
                    • 3599
                    Toyota stuff from 1980 or older.
                    • u3b3rg33k
                      • Jan 2010
                      • 2452
                      I still haven't figured this out, not even google knows. This is at idle btw.
                      And would anyone take a wild guess at what the crank power output might be at idle, no accessories, on let's say a ~200hp M52?
                      Idle as in ONLY idling the engine? or idle as in WOT at idle RPM?
                      the answer is either virtually zero (steady state means no spare HP), or a lot more than zero.
                      Ich gehöre nicht zur Baader-Meinhof Gruppe
                      Originally posted by Top Gear
                      Just imagine waking up and remembering you're Mexican.
                      Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        I had no idea; I stand corrected.
                        M70 is a good idea...and if you really need a 6, just cut the crank case in half and see if an M20 crank or something would fit....
                        Project M42 Turbo
