intake manifold replacement
  • hotrodlincoln
    • 413
    Is there a DIY for replacing the intake manifold?
  • CHIF8008
    • 3447
    with another stock one? bro just unbolt it, pull it off. put back on.
    type your question in google and pelican parts always have a simple step by step process of how to do everything like this.
    type in: how to replace e30 intake manifold. its the third one down. its for painting it- but tells how to take it off
    -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
    -The Beauty in the Tragedy-
    MECHANIC SMASH!!- (you all know you do it)
    Got Drop?? ;-)
    But of course
    E30s are know to be notoriously really really really ridiculously good looking
    • hotrodlincoln
      • 413
      I read somewhere about a pin underneath? Not put back correctly and you could be leaking oil? Is that true?
      • CHIF8008
        • 3447
        iv never heard about it. and you shouldn't have oil running in the intake manifold (at least i wouldn't think so). i have put a m20 back together roughly and didn't notice any "pin" of the sort
        Got Drop?? ;-)
        But of course
        • NigelStu
          • 827
          pin? nah.
          But there is a big tube that runs from crank case to intake.
          Replace the o-rings on either end of this tube to prevent leaks.
          Zip-tie the spring at the bottom of the tube to remove and replace; makes life easier.
          This is all assuming you are talking about the M20...
          Ben
          Thelma-Louise, the '88is Chump Car - back to M20 power!
          2014 ChumpCar Season Schedule!
          April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
          May23-25 Watkins Glen, NY: 4th, 5th, 4th
          October 4 PittRace Sprints: 2nd in C-class
          October 18-19 NCM, Bowling Green KY: 2nd, 1st!
          Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
          Find us on FB! Schaut Speed Motorsports
          • txtorquemade
            • 1758
            Yeah...hes talking about the bitch tube. Not a pin, a tube from IM to the bottom of the crankcase. Not a biggie. Follow the directions above, Zip-tie.
            sigpic 1987 325is
            • matias88e30
              • Dec 2009
              • 1110
              Easy... if it is ur first time just take a look at everything and all the bolts before start doing anything... it should take u no more than 30min... ull get it done
              no more boosted m20, 91 318i...
              • delatlanta1281
                Dart Master
                • Mar 2006
                • 10317
                Actually if you twist the tube while depressing it, it will "lock" itself down for a bit. Make sure your torque specs are correct, these tend to leak if not re-installed properly.
                Yours truly,
                Rich
                you kids get off my lawn.....
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Ah yes, the spring-loaded-tube-of-death. Definitely use zipties to compress and hold the spring. Makes life much easier.
                  • Dagamus(NM)
                    • 621
                    Also, make sure to have the washer inbetween the spring and lower o-ring.
                    Also, the t-stat housing being loosened will make it easier to get off and on.
                    Gun control means using both hands
                    Sex, Drugs, Rock 'n roll. Pick two.
                    • hotrodlincoln
                      • 413
                      So I still didn't do this. Call me the world's biggest procrastinator. But in preparation I bought that vent pipe and a new o ring from the dealer. The vent pipe is metal. Wasn't it plastic??
                      • 1fastm50
                        • Aug 2009
                        • 342
                        no they are all made of metal that i know of.
                        Racelands are cheap shit.
                        Originally posted by whodwho
                        So are r3v members
                        dude, this is R3v. there's like 40 project threads, and like 20 FS threads and 100 members ride threads of stupid shit. guaranteed laughs on every page. cut springs, rolled cars at 20mph, fishtank heater core, selling broken stuff, painting cars with paint brush, cheap wings, hella-flush and then there is Vlad, king of the eta M3
