THats insane, love the amount of progress this has made over the time this thread has beed around
Bmw e30 - Hunt for the 8sec is ON !!
29 Model A // 55 GMC 100 // 66 C10 // 72 BMW 2002 2.7 M20 Turbo // 75 CB500T Custom // 04 BMW M3 // 13 BMW 328i Sport
72 BMW 2002 2.7 M20 Turbo Build Thread // INSTAGRAM
Gewerkschaft der Polizei Sticker/Clings For Sale $8 -
Wow going for 900 on a pritty much stock block, that is very impressive. I supose a sleeved block is always an option then.
3.2bar!!! man that made me laught simply because of the crazy numbers I am reading. I really can't wait to see this thing fly down that strip.
What crank are you using, is it a BMW crank or a custom item?
yeah.. i think the orginal engine block will hold.
not sure why something has cracked now.. but in anyway it isent due to power.. we did 540whp
i think i could have something to do with the crash last year.. im hoping that the engine block is cracked and not the head..
3.2 bars is a lot but not here in sweden :)
the m20 isent known for breathing well so im guessing we are just helping it :)
the rear quarter panels are cut on the sides and underneath and pulled out.. then the gaps are filled with sheet metal. the doors are done the same way..
cut on the back and underneath and filled with sheet metal. i think it ended up beeing around 7-8cm wider on each side.Comment
The head is scrapped..
its poring water from 5 different places.
so all the work we put into it is waste.
i will now order an factory head.. im tired of broken heads.Comment
Dam. Cracks? Or Serious Destruction? Or Both?
So the head gurdle thing didn't really work or was it due to other issues?
I didn't know you can still order factory heads, I am looking for to pictures of the factory head.sigpicComment
my guess is that the job we did on it.. didnt left so much material left.. and when these heads are welded they tend to twist a bit.. and so did this one.. the hening we did of the camshaft bearing sections wasent enough "probably" so when it got warm it cracked.
the girdle wasent there..i didnt got the longer head bolts that i needed for this.
i got hold of an aftermarket head from italy.. says that the material in this one should be better then the original..
im posting frekvent updates on my facebook page. its so much easier when i got all my stuff in my iphone.
the new head wont be ported as the old one was.. we are just gonna better up the finish.. and then increase the boost map in the ecu to 53psi.. and aim for that.Comment
Ooh, is it a custom cast or just a modded stock head? Would like to know more about this.
So basically you fucked the head, and have decided that a stock head with more boost will fix the issue. It makes sense and I understand it but just saying it sounds silly lol.sigpicComment
its an aftermarket head, slightly ported and polished.
Beautiful car. Which headlights are those? They don't look like regular ellipsoids.Interested in vintage cars? Ever thought about racing one? Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
Elva Courier build thread here!Comment
- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plateComment
Dyno is done.
929hp and 1107nm at the crank.
short movie will come soon.Comment
my goal was more.. but i guess this will have to do :)
/kComment
