e30 cabrio weight distrobution?
  • Jean
    • 18228
    FFFffUUUUUuuuuu
    • autobot_lazi
      • 50
      Originally posted by aaron_silva
      My thinking is, if you have the 50lb weight in the rear and the battery up front, you can just take the weight out and replace it with the battery. That is what I did to no ill effect.
      Aaron
      This is prob the latest reply in the history of this site but i have a great idea....
      take out the weight in the trunk and replace it with the battery. Then take the weight that was taken out of the trunk and put it in the engine bay..... then you will still keep your car balanced.....
      • Justin B
        Sikky Nar Nar
        • Mar 2005
        • 4273
        Motor swap + battery relocation = closely balanced still too.
        • Justin B
          Sikky Nar Nar
          • Mar 2005
          • 4273
          Oh wow, an epic bump, then a recent one. This thread's been around.
          • Twelvizm
            • Oct 2009
            • 2108
            This needs another bump, just 'cause.
            • Pl3wA
              • 1589
              cut the battery in half and put it in the trunk, you still retain the weight distribution. duhh
              • Cabriolet
                • 9620
                i just did the relocation. guess what? you can't feel the difference.
                verts = not race cars
                so much front to disconnect weight balance is the lest of the issues.
                Much wow
                I hate 4 doors
                • spike68
                  • Apr 2009
                  • 1185
                  I just took the weight out when i dropped my car. I doubt there is need to relocate anything.
                  the weight of the battery isnt that much anyway. of course you wont notice a thing.
                  I don't even own this car anymore, but I'm too lazy to change the picture.
                  • scottinAZ
                    • Dec 2009
                    • 1312
                    biggest reason that would cause me to relocate the battery would not be to remove the dead weight in the trunk, but to get the battery out of the hot as hell engine compartment (longer battery life)
                    Here in Az batteries last about 3 years max in the bay, if not exposed to the additional heat, you can get another year or so out of them......
                    I saved 15% on my Bimmer parts by switching to ...
                    • Hey-U
                      • Mar 2008
                      • 560
                      Remove the ballast weight and replace with Luke sub box.
                      • Cabriolet
                        • 9620
                        Originally posted by Vivek
                        Does anyone know the real reason there's a 50lb weight in the trunk? I'm nervous to remove mine because of potentially losing control at high speeds or something. I'm pretty sure BMW designers didn't stick a weight in there because verts arent slow enough.
                        it was to help eliminate the "shuttle" feeling. as a dampener the weight keeps the car from rocking back and forth.
                        Much wow
                        I hate 4 doors
                        • Nsquared97
                          • 1656
                          ^What Cabroilet said. It's a vibration dampener.
                          • idanity
                            • Jun 2006
                            • 775
                            cabrios have a metal ballast
                            sedans have rubberised matting.
                            both wiegh 50 lbs, and both cars are happy without it.
                            if your nervouse about losing control at high speeds, i would check your tires, bushings and alignment 1st.
                            3 pedal club
                            200,k+ club
                            cabrio club
                            port-matched- polished- purring www.BMWpark.org
                            </div>
                            linux since 1999
                            • MAXELHOFF
                              • Jan 2008
                              • 414
                              Check it!
                              grain of salt:p
                              http://https://youtu.be/H8gOAzYchAE:ot:
