LSD or not
  • bernzpeed
    • 3917
    LSD or not
    How can you tell a car is equipped with LSD?
    89 E30 S52
    Transaction Feedback.
  • Predzy743
    • 644
    2 ways.
    Jack the car up. spin the tires. If they both spin in the same direction.. LSD
    Look underneath the car, look on the diff cover. There is a metal tab with numbers where you would find your diff ratio. If there is an S stamped on it. Its an LSD
    Hope this helps.
    88 Zinno M3
    • IxTech
      • 471
      ya what he said
      http://r3vlimited.com/board/showthread.php?t=201774
      • bernzpeed
        • 3917
        thanks that's exactly what i was looking for. so does an IS have LSD standard?
        89 E30 S52
        • TurboJake
          • 3780
          Typically, yes
          By typically I mean they come with them standard. But may be switched from previous owners
          Leave Me Transaction Feedback
          • Predzy743
            • 644
            ^^ Exactly. And not all 325iS's have 3:73's. Mine had a 4:10 so double check if that matters.
            88 Zinno M3
            • Overlord475
              • Dec 2010
              • 799
              Pedzy743 is right... Mine also has a 4.10LSD
              --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
              • AndrewBird
                The Mad Scientist
                • 11898
                My 318iS didn't have a LSD, so not ALL iS cars came with them.
                • Butler
                  • Nov 2009
                  • 1613
                  One tire fire? Go drop the clutch.
                  -Nick
                  Originally posted by 87e30
                  First of all: calm the fuck down; second of all; cool story bro.
                  • Jesse30
                    • Jan 2007
                    • 3936
                    ^ like.
                    thats how i always tell, burnouts are the best sign
                    • Wh33lhop
                      • 11705
                      It's likely that it came with one, but was replaced with an open unit.
                      Originally posted by Jesse30
                      ^ like.
                      You can still light both tires up with an open. But it is unlikely that you could spin donuts with one.
                      For the most reliable result though, just jack up the rear of the car and spin one wheel.
                      paint sucks
                      • CincinnatiKid
                        • Nov 2007
                        • 716
                        As far as I know it was an option on the 318is and standard on 325is. Go find a gravel lot and do a burn out, then look at your tracks.
                        1990 S50 goodness.
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          Yep, it was an option on the 318is and standard on the 325is.
                          Project M42 Turbo
                          • F34R
                            sLaughter
                            • 12376
                            Here is a fast way to find out what kind of LSD you have if you have one.
                            Lift both rear wheels off the ground with enough room under the car to support it with jack stands. Then slid under and mark the drive shaft then mark one tire with white caulk or something easy to see when spinning the wheel.
                            Now once that is done lay down and have a friend spin the tire 360 degrees once while you count the rotations of the drive shaft. Each 360 rotation counts towards 1. So if it spins 3 and a half times you most likely have a 3.46 LSD. You can do this with open diffs too.
                            Here is a link listing the diffs so that you can compare the above to figure out what you have. http://en.wikipedia.org/wiki/BMW_3_S...30)#Drivetrain
                            Instagram: @BWeissLeather
                            Current cars:
                            ~ '87 325 M30B35 swap
                            ~ '87 535
                            ~ 01 540 Msport 6spd
                            ~ '06 X5 4.8is
                            • Wh33lhop
                              • 11705
                              That would explain a thing or two.
                              paint sucks
