Trying to pick up an E30 for a DD
  • Wanganstyle
    • 2828
    the first E30 I had for commuting use was a m42 318is. Handles the best out of all normal e30's
    My current DD is a 325e. for Daily use, I'd rather have the ETA as the conditions I am in require easy lazy torque. Fuel economy is also great with the lower gearing
    early ETA's have lazy 2.79 final drive ratio, later ones 2.93. I installed a 3.07 LSD into mine, pretty good combination daily / mountain cruising car.
    the M42 is a bit high strung and rough on vibrations for daily use, if going with a 4 cylinder I prefer boxxer 4 cylinder engines to inline.
    • txtorquemade
      • 1758
      Originally posted by Kershaw
      if its a 91 it has an m42. swap an LSD for the open diff and rock it.
      i loved my 325es. it was a great car. so much fun to putt around in because all the power is in your normal driving rpm range.
      Done
      sigpic 1987 325is
      • Nick_S
        • Apr 2011
        • 3658
        Originally posted by txtorquemade
        Done
        91 318is M50 swapped
        05 Honda Pilot
        24V swap thread
        • Kershaw
          • 11822
          ^ no idea. maybe he was agreeing with me.
          absolutely. i loved my eta because of the easy lazy torque as you put it. just made it so nice to drive around. and i really think it has perfect gearing. you never feel like you need another gear on the highway.
          m42 is definitely high strung.
          AWD > RWD
          • Nick_S
            • Apr 2011
            • 3658
            Cool thanks for the input. Looks like if I can talk the guy with the eta down a bit I'll pick that. And looks like the 318i I was looking at is sold and I really don't feel like driving to detroit for the 318is.
            05 Honda Pilot
            24V swap thread
            • urbancynic
              • Dec 2008
              • 384
              I like my eta. If I could get it through emissions, and fix a couple minor bugs I'll be happy with it.
              If I was doing a track car or something I'd go for an i. Since its just a daily I'll stick with the eta. Probably chip it. Best thing you can do for an eta, aside from basic maintenance anyway.
              • Nick_S
                • Apr 2011
                • 3658
                Hmmm so a nice 318is just popped up about 15 miles from me. Hopefully go look at that tonight! Got a few dings, odo doesn't work (go figure), short shifter, h&r springs and bilstein shocks. The guys says its originally from New Mexico and is rust free.
                05 Honda Pilot
                24V swap thread
                • Lance Racing
                  • Jul 2005
                  • 2340
                  Because the eta was low revving and designed around torque, it's a good cruise around town car. And low revving means the engines go forever. As stated, you could swap out the rear diff to get a little more pick up from a start.
                  A mild aftermarket spring/shock upgrade will transform the car hanlding wise. I don't like my street E30s to have rock hard suspensions. But a tired stock suspension will feel like a marshmallow.
                  Lance Richert '88 M3, #35 PRO3, i3 etc.
                  www.LanceRichertArchitect.com
                  2019 E30 Picnic Weekend: June 22-23 2019
                  • Wanganstyle
                    • 2828
                    I put cabrio suspension on my ETA to have more oil pan clearance, lots of speed bumps near me.
                    3.07 final gear bump from stock 2.93 was nice, I don't think fuel economy changed as I do mostly short drives, the freeway rpm difference is barely noticed but the acceleration seems same with less throttle needed - perhaps I save fuel.
                    • txtorquemade
                      • 1758
                      Originally posted by Nick_S
                      yes.....agreeing!!
                      sigpic 1987 325is
