Official Fabrication & Welding Porn Photo Thread
  • mrsleeve
    • Mar 2005
    • 16386
    #106
    Originally posted by kalib0y
    not automotive related but Ill contribute...
    I work in a shop that builds custom ASME code pressure vessels and Space Thermal vacuum simulation chambers so the weld quality needs to meet stringent requirements.
    here are some pics from today:
    We are building our vacuum chamber that we will be doing titanium welding in:
    vacuum tight weld to hold up to 10x10^-12 Torr space vacuum
    ASME code jacketed pressure vessel
    ASME code pressure vessel head with an 4ft ID x11in thick flange. Head outer weld required 60 passes on the outside and 35passes on the inside with a dye penetrant check and radiograph to make sure there are no inclusions at all. The weldment had to remain heated so imagine welding in an oven...
    Vacuum flange
    "Un-Weldable" Munze metal, we developed a weld proceedure and are first to sucessfully weld Munze metal and get it structually certified by the state of CA
    I dont do much ASME work and when I do its all B31.1 or B31.3 for piping. but mostly work with the API 1104.
    I assume you guys are welding to BPVC Section 8 arent you????
    I am an X-ray hand so I am the one who looks though the weld
    Originally posted by Fusion
    William Pitt-
    • flyboyx
      • 8371
      #107
      Originally posted by Brian 89 325i
      What is this "muntz" metal used for? Seems like it would have pretty limited application?
      -Brian
      historically, (starting in the 1830's) it was used to clad the bottom of sea going vessels because it was much cheaper than copper but contained the same anti sloughing(wont allow barnacles and algae to grow on its surface) and anti corrosion properties as the pure metal. other than being used in corrosive environments as a cheaper alternative to copper, i don't believe it has much application.
      Gigitty Gigitty!!!!
      • Good & Tight
        • Apr 2004
        • 2057
        #108
        Some of my welds. Remember nice looking welds don't add HP. Self taught no school.
        I probably have made close to 100 manifolds.
        My drive shaft holding 622rwtq mig
        B35 mounts mig
        Mig 16 gauge
        Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
        ____________________________
        E-mail Panayiotisx2@gmail.com
        Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
        • einstein57
          • Jun 2007
          • 10780
          #109
          So that's why my manifold cracked and weld beads chewed up my turbo. I kid, i kid.
          www.gecoils.com
          • b*saint
            • 3794
            #110
            Here are my two piece clamps I designed and cut out on the laser at work. I didnt like anything the autoparts store had. It was either something ridiculous looking for something cast and expensive. These are .125" with a .125" backer plate. The customer had the wrong die so I had to hand form the bends. Kinda sucks but I wanted my exhaust back on this weekend.
            Ma che cazzo state dicendo? :|
            • kalib0y
              • Dec 2004
              • 3620
              #111
              -Brian
              In our case, it was used for building a greenhouse/observatory for the Huntington Library Garden. The owner also wanted us to build copper pressure vessels which turned out really cool.
              Yes, my work is ASME code Section 8 DivI and we also have the U, R, S, PP, and N stamps. We just got the N stamp because we will be building HSLA100 spheres where they will be detonating small bits of uranium in them.
              95 7.1L 16V E36 M3
              Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
              LIKE my Facebook Page! CLICK HERE
              • ck_taft325is
                • Sep 2007
                • 6880
                #112
                I'll be welding platinum in the coming months.
                Yeah. G.
                Need a part? PM me.
                • gone002
                  • 880
                  #113
                  ok this thread needs more shit!!!! dont make me go out to the garage... =)))
                  bimmerboltsandparts.com
                  bring back the neeked broads!!!
                  • MonkeyMadness
                    • 3251
                    #114
                    woo hold on this site doesn't support or promot porn! :hitler:
                    • gone002
                      • 880
                      #115
                      they did kill the hot gurl thead!?!?!?
                      thats lame!!!
                      • Jaxx_
                        • Dec 2009
                        • 1880
                        #116
                        I think I'll just put this here...
                        • 5Toes
                          • 9836
                          #117
                          ^ I am confused
                          • der affe
                            Technical
                            • Dec 2005
                            • 8452
                            #118
                            I love engine turned metal!
                            What is that on?
                            I always wanted to try it, but never had the patience to set it up in the mill.
                            • Jaxx_
                              • Dec 2009
                              • 1880
                              #119
                              What is that on?
                              it's an entire delage 33 engine.
                              • Cabriolet
                                • 9620
                                #120
                                I demand more pics!
                                Much wow
                                I hate 4 doors
