The Official Engine Porn Thread
  • CincinnatiKid
    • Nov 2007
    • 716
    #46
    1990 S50 goodness.
    • der affe
      Technical
      • Dec 2005
      • 8452
      #47
      Originally posted by Mlarsen
      Where did you get that green hose from, my friend is looking for some.
      It is ltw aero space kevlar reinforced with xrp swedged ends. Spares from my friends dragster. Think silly nasa $.
      • M42Power
        • Dec 2009
        • 519
        #48
        Originally posted by CincinnatiKid
        Holy V16 batman
        Originally posted by kendogg
        Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
        OG RACECAR
        • JasonC
          Site Manager
          • 14451
          #49
          1992 BMW 325iC
          1978 Chevrolet Monte Carlo
          • Mlarsen
            • 4082
            #50
            Yeah, we found some. I think it was like 60 bucks per ft. for AN 8.
            • der affe
              Technical
              • Dec 2005
              • 8452
              #51
              Yea, that breather is -12!
              • pharow
                • Jul 2010
                • 1021
                #52
                ?-What did the 16 cyc. come in? (post #49)
                '02 Outback wagon
                '87 325is 5sp
                '93 Kawasaki ZR1100
                • mohamadr89
                  • 282
                  #53
                  bmw's secret 7 series model
                  e32 prototype with 6.7 v16 engine
                  mtech 2 325ic
                  http://www.r3vlimited.com/board/pict...pictureid=7968
                  check out my donut vid
                  http://www.youtube.com/watch?v=Tw0paUP1FEQ
                  • Massimo
                    • Jan 2008
                    • 3207
                    #54
                    Man that engine had so much potentual. It only has a 74mm crank and 8.8:1 compression. Bring the rev limiter up to 8 maybe 9000rpm and increase the compression to 10.5:1 and you could probably push 400kw/600bhp
                    • Jean
                      • 18228
                      #55
                      It probably had a little more potential than the old v12..... not much.
                      • mohamadr89
                        • 282
                        #56
                        yea i think it has about 400 hp. hey i see your located in sacramento. do you work on cars? and what engine is in your e30?
                        mtech 2 325ic
                        • deansbimmer
                          • 674
                          #57
                          These threads start to suck when people start posting pics of their engine bays. And when we end up with two pages of discussion between any pictures... Stop that!
                          Engine bling:
                          • McGyver
                            • 4628
                            #58
                            Originally posted by KamakaziX
                            I just came in my board shorts.
                            wait, where are the wiper blades for the HCS?
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              #59
                              Originally posted by JasonC
                              slant6? nice. Any specs on it?
                              Correct. Never made it past prototype stage however as the engine was so big the radiators had to be moved to the trunk. Not very marketable:
                              • DTM190
                                • Nov 2008
                                • 1107
                                #60
                                This is a look and listen, while being on the topic of V16s and engine porn,
                                BRM V16
                                Specs
                                Configuration 135º V16
                                Location Front, longitudinally mounted
                                Construction light alloy block and head
                                Displacement 1.496 liter / 91.3 cu in
                                Bore / Stroke 49.5 mm (1.9 in) / 47.8 mm (1.9 in)
                                Compression 6.0:1
                                Valvetrain 2 valves / cylinder, DOHC
                                Fuel feed 2 SU Carburettors
                                Aspiration Rolls-Royce Centrifugal Supercharger
                                Power 525 bhp / 392 KW @ 10500 rpm
                                BHP/Liter 351 bhp / liter
                                We are talking 1951 here.
                                And the sound, ugggggggggggggggggg
                                Volume up
                                Excuse me while I fap
                                first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
                                if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
