Which 17lbs injectors can i use with m20?
  • schtozo
    • 1455
    Hi, i would like to know which 17lbs injectors drop as a plug and play in my m20. Any tips would be helpful. I couldnt pass on a mark d chip for 17lbs injectors deal.
    Thanks
    One of the best threads you will ever read
    http://www.r3vlimited.com/board/showthread.php?t=221813
    Nice trailer of my e30
    http://www.youtube.com/watch?v=TTjtG...e_gdata_player
    If i sold you something please leave feedback here
    http://www.r3vlimited.com/board/showthread.php?t=217142
  • Sagaris
    • Sep 2009
    • 2243
    Stock injectors for an M50b25
    • nomansland92
      • 1657
      I used green top m50's
      IX being restored here
      Ix turbo build here
      • schtozo
        • 1455
        Are all m50 injectors green topped? What about o rings? Should they be m20 or m50 specific or are they the same?
        • kalib0y
          • Dec 2004
          • 3620
          I have a set of stock s50 injectors I pulled out yesterday that should work for you. let me know if you are interested in them.
          95 7.1L 16V E36 M3
          Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
          LIKE my Facebook Page! CLICK HERE
          • Brandon12V
            • 1318
            the output of all 17lb injectors should be the same. You need to look at the spray pattern, impedance, and pulse width they retain. This can be found pretty easily on the internet and you can compare with stock.. 19lb will work with your MarkD tune as well so don't rule them out as they are easily accessible if not more. I use bosche type III.
            Originally posted by Ryan...
            It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
            • DmcL
              • Apr 2009
              • 260
              anything that flows 17lb at 3 bar pressure and is high impedance will do. the M50B25 injectors work well FYI.
              part number of them is 0280150415.
              Currently E30-less
              - EthosMotorsports.com
