your opinion/fact on which tranny to get
  • Brian e30
    • 253
    1989 bmw 325i . Going to swap for a m50/m52 . the tranny i have now also needs to be swapped , it doesnt have reverse, 1st, or 2nd . So when i buy the new motor im going to need another tranny . which should I get for these engines
  • b*saint
    • 3794
    Go for one with big boobs. It'll get you in the mindset its a "she" faster.
    On another note, Getrag is a popular unit. But I imagine the easiest would be to get a tranny where you dont need to mix and match driveshafts to get it right.
    Ma che cazzo state dicendo? :|
    • z31maniac
      • 17566
      Search, search search search, sseeeeaaaarrrrrccchhH!!!!!!
      There are at least 4 different transmissions you can use with that engine. Any E36 trans will require a new ratio in your diff as well, since they are a non-OD trans.
      www.gutenparts.com
      • colorado_cabrio
        • Sep 2009
        • 891
        Getrag 260
        • Brian e30
          • 253
          haha thanks so far guys .. much help lol :P trust me btw, i did my research im just a little confused because just like he said ^^ there is like 4 diff kinds i can use .. i want a good one but if a regular getrag 260 is compatible with a m50 on it , i might aswell go that route kuz a stock tranny is helllaaaa cheap
          • Brian e30
            • 253
            bump , so still looking into this , ive came to the conclusion that if i go ahead and grab a m50 engine and another getrag 260 , im good ? keep the same lsd ?
            • samiam3356
              • Jul 2009
              • 1901
              yes
              you will need a new trans brace for the 260 to work. White325is (mike) sells them.
              Originally posted by Roysneon
              $5 shipped?
              Originally posted by MarkD
              You are a strange dude, I'n not answering any more posts from you.
              • Brian e30
                • 253
                ^ thanks im about to look into that now .. 3.73 lsd should be fine if i plan on going on boost ?
