what tools to use?
  • mr.vang
    • 4371
    what tools to use?
    i'm having a hard time putting the snap ring(#6) back on its place. the spring is too hard to be compress by hand. is there any specific tools to use?
    http://realoem.com/bmw/showparts.do?...47&hg=32&fg=30
  • mrsleeve
    • Mar 2005
    • 16386
    snap ring pliers/tool
    Originally posted by Fusion
    William Pitt-
    • mr.vang
      • 4371
      i don't have a problem with the snap ring itself but the spring...it's too hard to be compress by hand..
      • mrsleeve
        • Mar 2005
        • 16386
        OH Grow a pair then Sally Push harder
        :P
        William Pitt-
        • herlsy
          • Sep 2009
          • 339
          Large flat head screwdriver works, just make sure it is flat against the column, otherwise you'll screw up the spline.
          • mr.vang
            • 4371
            that is what i have been using.
            • mr.vang
              • 4371
              finally got that fucker to go in
              • StereoInstaller1
                GAS
                • 22679
                YAY! I have not dealt with that spring myself, but generally I use a couple of wire ties to compress a spring like that, just make sure you can clip them and remove them when it is time.
                Closing SOON!
                Thanks for 10 years of fun!
                • jrobie79
                  • Mar 2006
                  • 2526
                  i used a big spacer made out of some 3/4 copper pipe with a couple washers that fit around the column tightly and just tightened it down with the nut and slipped the clip on, worked like a charm
                  1991 318i ---- 308K - retired
