Z3 rack: best mod to date!!
high pressure hose is from the pump to the rack. the low pressure hose goes from the rack to the res. simple!Comment
I have two new, unopened tie rod assemblies (inner and outer) for e30. Should I order new e36 outers ? since my z3 rack came with inners and it just needs outers? or should I put the whole e30 tie rod assembly on instead?09/1989 325i 4 Door
+M30 Swap
+Z3 Steering RackComment
put the whole e30 tie rod assembly on it. simple as that!
when i took it to get aligned it was just barely off too.Comment
'96 + 328/M3 are 3.2 turns
E30 M3 is 3.5 turns
Stock E30 is 4 turns
I've driven each type of rack now, and the Z3 1.9 one is a bit twitchy for me on the freeway if you have power steering AND light wheels, with responsive tires.
I used to have the '98 M3 rack on my swap car, with pretty heavy 17s, but responsive FK452 tires and I loved it! I also had full coil-overs, with polyurethane offset M3 CABs, M3 sway link conversion and a polyurethane steering coupler.
Also if anyone is doing this swap, make sure to buy a polyurethane steering coupler from Ireland. It cleans up any extra "sloppyness" left from a rubber steering coupler and is only $20!Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
The Mavel racks come with lemfoerder inners so they are good quality. I just removed mine and installed new complete lemfoerder (e30) and sold the inners that came with the rack. This is my favorite mod next to a snailComment
How so?
Least overall travel of all E36 racks
Heavily progressive behavior
Slowest overall turn-to-travel ratio of all E36 racks
Remember there is a lot more to a steering rack than the lock-to-lock figures that everyone loves to throw around. Is the 95 M3 rack crap in itself? No, but I tend to be more emphatic about the point because of the misinformation out there regarding the rack and the high prices it fetches. $300 for a rack that is inferior in every way to a regular $100 E36 rack? THAT'S crap.
I made a thread awhile back a little more in-depth when I stumbled upon a thread about E36 M3 guys swapping for Z3 racks.
<3paint sucksComment
that was another hiccup, I swear I've never felt dumber than I do right now. I don't have those two intertwining fork looking things, it's just the u-joints and the steering coupler (flex disk). And I don't know what year e30s were airbags so I don't know if all I have to do is grind the wall a little bit.
I've replaced an entire rear subframe bushings and all and this, which seems easier is holding me back more. :(
Awesome, good to hear this, just makes me want to get mine done quicker.09/1989 325i 4 Door
+M30 Swap
I have see everone saying the M44 Z3 rack is the one to get, but when I look up that number on ETK it show that part # 32131095575 fits the 1.9 2.5 and 3.0 Z3. So I'm wondering if all these Z3 reman racks out there are all the 2.7 lock to lock linerar style or they mixing them up with other e36 racks and calling them all the same. Just a tad bit confused and want to order the correct one from my supplier, which could not help with that answer. Thanks in advance.Comment
