So ummm... should my diff flange be doing this..?
  • Brandon12V
    • 1318
    I'm literally right in the middle of rebuilding the rear end.. Axles, wheel bearings, subframe bushings, trailing arm bushings, blah blah blah.. As I was checking play in the axles, I noticed the axle shaft flanges separated completely from the differential.. WTF? Standard? It's a 3.73lsd
    Originally posted by Ryan...
    It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
  • E30SPDFRK
    • 5714
    They just pop out, push on it and it should pop right back in
    Byron
    Leichtbau
    • Brandon12V
      • 1318
      okay good. should there be enough play in my axles to allow this?
      • AndrewBird
        The Mad Scientist
        • 11898
        There is a snap ring that holds it in place. Might be worn or missing. Also looks like your output shafts seals are shot, hence all the oil on everything. Would be a good idea to replace them.
