Upgrading Suspension on my Vert
  • monoblanco
    • Mar 2008
    • 310
    Looking at the suspension kits available at Pelican parts.
    Since I'm looking to upgrade the suspension I figure this is a good time to lower the car.
    For what I can tell on the site the Stage 3 suspension kit would do the trick.
    Are there any of these kits are intended for the 318ic?
    http://www.pelicanparts.com/BMW/cata...SUSwiz_pg2.htm
    There is a stage 2 suspension kit intended for the vert, but I don't see anything indicating it will lower the car.
    http://www.pelicanparts.com/BMW/cata..._pg1.htm#item1
    Thanks.
    monoblanco
    www.passportsoccer.com
  • e30lov
    • Jul 2008
    • 1597
    Go there please, for the price that pelican lists you could have a decent coil-over setup and it would be fully adjustable.
    `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
    • ill4noreason
      • 2710
      ground control 450/750 rides nice its what they recommend on verts and what I have on mine. If you can afford konis go that route if not even stock works with bumpstops.
      My Multi car part out. Need a part? Pm me...
      http://www.r3vlimited.com/board/showthread.php?t=193051
      Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
      http://www.r3vlimited.com/board/showthread.php?t=215044
      Have you done business with me? If so leave me feedback here...
      http://www.r3vlimited.com/board/showthread.php?t=188307
      • jasonsnoddy
        • 1900
        yeah, dont buy stuff off pelican haha
        Originally posted by stewie30luvr
        ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
        Originally posted by JakeP
        with a coathanger
        • msportr430
          • 120
          what the difference between the standard coilover and the double adjustable. This is referring to the GC kits
          • 325ix
            • Aug 2009
            • 7783
            The standard shocks are only adjustable for stiffness where as the doubles add in adjustment for rebound.
            • TimR
              • Mar 2008
              • 549
              Stock vert front springs are 1.5 coils taller than reg. E30's, they weigh more too, thats why they have thier own lowering springs if you go what way. http://www.r3vlimited.com/board/show...t=vert+springs
              • McGyver
                • 4624
                but you can just run regular coupe springs. i have coupe H&R Race in my vert and it works fine.
