1987 325i smokes
  • kreaglewon
    • Jul 2010
    • 27
    1987 325i smokes
    Hi guy's, I have a 87 turbo'd e30 and it smokes when I barely get on the gas and when I stop at lights. I thought the turbo had blow-by and replaced it about a week ago. It started smoking within 3 days after the install. I can drive it hard with the boost up to 6psi. and sometimes it won't smoke othertimes it will. I notice it really likes to smoke when the car is in reverse and I back up to park. I checked compression and all cylinders were at 168psi., I assume the rings are good. The smoke comes right out of the exhaust.
    Anyone else know what I should check ?
    http://i67.photobucket.com/albums/h295/kreaglewon/car.jpg
  • StereoInstaller1
    GAS
    • 22679
    When was the head last rebuilt?
    Closing SOON!
    Thanks for 10 years of fun!
    • TurboJake
      • 3780
      Instead of doing a compression test, do a leakdown test.
      Leave Me Transaction Feedback
      • kreaglewon
        • Jul 2010
        • 27
        I bought the car about a year ago. I was told that it had been rebuilt within 40k miles. I'll try the leakdown test and let you know the results.
        • StereoInstaller1
          GAS
          • 22679
          When you do the leakdown, add a teaspoon of motor oil after you do it the first time. If your numbers go way up, blame the rings.
          Closing SOON!
          • kreaglewon
            • Jul 2010
            • 27
            The problem seems to be a vacum issue...it tends to smoke more when in reverse or slowing down...........Sometimes I can drive it hard and t doesn't smoke.
            • scottinAZ
              • Dec 2009
              • 1312
              telltale sign of valve guides and seals crapping out
              I saved 15% on my Bimmer parts by switching to ...
