What Spark Plugs For a 1987 Turbo E30 ?
  • kreaglewon
    • Jul 2010
    • 27
    What spark plugs are best for a turbo'd 87 325i ?
    (2.7 head on a 2.5 block)
  • reelizmpro
    • 9552
    NGK 7's.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • b*saint
      • 3794
      Ma che cazzo state dicendo? :|
      • redsubdivisions
        • Feb 2011
        • 1762
        BP7ES's. Running it in my current build. My buddy ran it in his boosted M20 and it was ideal.
        1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
        2012 Passat TDI - DD Duty
        2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
        • foofopps
          • Sep 2009
          • 529
          [quote=(2.7 head on a 2.5 block)[/quote]
          Sweet setup
          Originally posted by b3albakii
          the head was okey .. and in a good mood
          no i didnt over heat it so much
          www.blunttech.com
          • jaywood
            • Jul 2010
            • 4528
            NGK BPR7ES. They're 2 degrees colder then stock
            • ak-
              • 12422
              wut
              1991 325iS turbo
              • kreaglewon
                • Jul 2010
                • 27
                NGK 7's.
                Thanks Barry, I'm gonna go with the NGK Races.
                Looks like we have similar taste in cars.
                87 E30 325i Stroked and Turbo'd
                97 E39 528i 5spd. Dinan Cold Air Intake Hartge 19" CS3's
                • IxTech
                  • 471
                  all about the stroker turbo. same things in my ix. how many pounds u running and what kind of numbers you think youre putting down?
                  http://r3vlimited.com/board/showthread.php?t=201774
                  • e30trooper
                    • 11576
                    Originally posted by ak-
                    wut
                    2.5 blk with 2.7 would be stupid high compression , no tarboing , im sure he means 2.7 lock with , b25 head
                      • 37833
                      I have been running stock Bosch Super, may change that depending on tuning whenever I get that done.
                      Grover Beach, California
                      BimmerHeads.com
                      • kreaglewon
                        • Jul 2010
                        • 27
                        I recently checked compression...it was at 168psi. I was surprised that it was so high, I expected it to be around 150psi.
                        I bought this car from someone that didn't have the cashoala and BMW appreciation to build it correctly. I did the suspension, replaced the turbo, and plan to install megasquirt. It's gonna take a few months but, it should be nice when I'm finished. 'm not a cheapskate and plan to do it tastefully.
                        I'm assuming it should push around 230hp, It's set to 6psi at the moment.
                        It's also got a 4.10 LSD.
                        She smokes at lights sometimes....I'm not sure why, any answers ? The smoke comes from the exhaust as if the turbo had blow by. I replaced it and it's better buts till not smoke free.
                        • bmwguy325is
                          • May 2011
                          • 1263
                          Could be value guides.
                          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
