To anyone with a strut bar
  • Suspence
    • Jul 2009
    • 943
    I'm running an I manifold and a IE strut bar, the manifold is hitting the strut bar and it's super loud. Guessing it has something to do with my tranny mounts or engine mounts? Any help would be nice...
  • E30_(1st Musk)_
    • 2008
    i think there is a difference in bars. i think they have 2 sizes. check with them
    might want to check your mounts either way since they are important
    • bmwguy325is
      • May 2011
      • 1263
      Sounds like you have a broken motor mount. If you had an early car the alt would have chewed through the lower rad hose. I have an IE strut bar and it is no where near the intake.
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • BrownBeanE30
        • 965
        yea your motor mounts are bad and its making your engine jump around
        Originally posted by InuFaye
        silver is old man color car. you need dat BRO-SECA BLUE.
        so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
        An S5x is like the girl you want to marry - an m30 is the girl you don't bring home to mom.
        • e30shmobberr
          • 1934
          motor mounts for sure. mine when and shifted the engine a few inches into the radiator hose -_-
          Patrick - IG:niicknac
          RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
          • Sagaris
            • Sep 2009
            • 2243
            I have about 5mm between my intake manifold and IE bar with brand new engine mounts. I was worried that it would rub when the engine moved around, but with new mounts the engine doesn't move hardly at all.
            • Suspence
              • Jul 2009
              • 943
              Poop.
              I tried fitting a razor blade between the intake manifold and the strut, wouldn't even come close to fitting... when I start it I just clanks around. Anyways, maybe I should look into urethane mounts? Anyone have a recommendation?
              Thanks for all the help guys...
              You can hear in this video the clanking sound at the beginning...
              • Sagaris
                • Sep 2009
                • 2243
                If I were you, I would run longer strut mount studs and use a 3/16" steel plate as a riser for the strut brace. Changing engine mounts changes your driveshaft angle and shift linkage angle. Perhaps not enough to mess things up, but it would sure suck if it did.
                OR, you can remove the brace and flatten the tubing where it rubs.
                  • 37833
                  Why do you need urethane mounts? Put some OEM style Meyle mounts in there and call it good. It shouldn't be hitting, the bar was designed for M20 cars.
                  Grover Beach, California
                  BimmerHeads.com
                  • bzboardz
                    • 1096
                    did you replace the mounts when you did the engine? or are they old?
