No neutral safety switch?!?
  • 6gen91
    • 712
    Car is an 86' 325e. Was auto until i converted to a 5spd. There isnt a neutral safety switch on the car though. I have a green/white wire, green/black wire, and a blue/white wire. Other than that, theres no plug that i can cut and splice into. Also, on the opposite of the auto shifter, there is a brown wire and another green/black wire.
    Everything is so confusing and I've been stuck on this for a while now. I've searched everything and can't find any info relating to my situation!! I looked at yoshi's writeup and still has wondering.
    Any input will be appreciated!! Thanks guys!
  • scottinAZ
    • Dec 2009
    • 1312
    There isnt one. My Eta is factory 5 speed, and I can start it in gear, with the clutch out.
    IIRC the green/black and brown wires were for the light on the auto shifter. there is no such animal on a 5 speed. the reverse light plug should be there for you to just plug in.
    I saved 15% on my Bimmer parts by switching to ...
    • 6gen91
      • 712
      Its not starting at all and its mind boggling. Its killing me, ive tried it all and nothing is working to start this car.
      • dreamer420
        • Sep 2009
        • 468
        yoshi's write up has an image made in paint that shows what wires to splice together. its very easy.
        if the wires are spliced correctly the car should start, clutch does not need to be depressed.
        • 6gen91
          • 712
          my point exactly, yoshi's writeup has nothing to do with what im asking. His shows wires that my car doesn't have, which clearly makes it difficult for me to complete.
          • TurboJake
            • 3780
            Grab a multimeter
            Put the auto shifter in park
            Find out what two wire have zero resistance, or make a tone.
            connect those two wires on your car.
            done
            Leave Me Transaction Feedback
            • 6gen91
              • 712
              Don't have the auto shifter anymore, its quite depressing lol
              • TurboJake
                • 3780
                Way to go....
                Find a 12 v signal. Run a wire from it. Or grab it straight from the battery.
                Put a 2.5 amp fuse inline
                Start touching wires with the 12v signal while attempting to crank. When it cranks, you know what wire you need getting a 12v signal. If you pop the fuse, don't touch that one again. Unless it pops when cranking. Then you just know you have the right wire with too small a fuse (The fuse is purely to prevent damaging anything else.)
                Pictures will greatly help us with this one too
                • 6gen91
                  • 712
                  all so confusing haha! any easier way to start this car up? anyway to hotwire a switch from the starter etc?
                  • TurboJake
                    • 3780
                    If you really find this task confusing, and are willing to run a hotwire directly to the starter.
                    I refuse to help you any more. This is a ten minute job. at most
                    • 6gen91
                      • 712
                      Im just looking for the easiest and quickest route bud.
                      • BrownBeanE30
                        • 965
                        ok dude brown wire is ground just to let you know
                        Originally posted by InuFaye
                        silver is old man color car. you need dat BRO-SECA BLUE.
                        so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
                        An S5x is like the girl you want to marry - an m30 is the girl you don't bring home to mom.
                        • 6gen91
                          • 712
                          as for the others ?
                          • grantlacey11
                            • Jan 2009
                            • 680
                            Originally posted by TurboJake
                            Way to go....
                            Seems pretty easy and quick to me. Shouldn't take more than 20 minutes.
                            • bimmer630
                              • 1230
                              You dont have to splice anything, Isnt there some connectors you connect and or disconnect under the column, since all e30s were set up for manual trans, and the autos were sorta an add-on?
                              I forget what the wires are, do a search on it. I had a problem with my swap, the car wouldnt start, and I found the post about swapping wires and she fired right up
