I now have 3 washer pumps(now with pics)
  • rs4pro3
    • 5808
    Just got done installing the Full Euro Headlight wiper kit. Here is everything that I've done
    Euro H1 High and low lights, with city bulbs
    Headlight wiper motors
    Headlight wiper wiring harness
    Control unit
    Brand new washer tank
    3 wiper pumps
    TONS of New washer lines routed everywhere in the car
    All new fittings, valves, etc...
    Intensive wash wiper stalk
    Updated Intensive wash wiper control relay
    Some mild rewiring of the fuse box was needed for the windshield wiper control relay, and some wiring for the headlight wipers, but nothing major.
    The Intensive wash function is nice to have, when you press the end of the wiper stalk in, a third pump kicks in and squirts Concentrated fluid and then runs the wipers for 10secs. The washer resivor has a seperate built in tank for the Intensive cleaner, then there is the main tank with 2 pumps for the Windshield and Headlight wipers. I just have to tear down the Passenger headlight wiper motor, as it is seized then the whole thing should be working :twisted:
    Yes this in on a slow eta, but at least it looks cool 8)
    85 325e 2.7 ITB'd stroker
  • Rob
    • 8166
    but does anything work?
    BEERTECH
    • rs4pro3
      • 5808
      Yes, it all works but the Passenger side wiper motor.
      • James Crivellone
        Head Janitor
        • 6304
        You have a complete parts list by any chance? I have all of the system, just not wired.
        does it actually work well? IE the cleaning the headlights portion? I perfer them for looks more then anything
        • rs4pro3
          • 5808
          Not sure yet, how well they work. I manualy supplied power to the Driver's motor to make it work, as the passenger has to work for it to work. But the washers squirt the headlights, and the intensive function is real nice as you just press the stalk, and don't have to hold the lever pulled back.
          I'll put together a simple parts list and post it
          • rs4pro3
            • 5808
            Windshield wiper control unit for Intensive wash-61311369829
            Headlight wiper wiring harness-61121380675
            Left Wiper motor-61631370895
            Right Wiper motor-61631370896
            Resivor-61671370777
            Headlight wiper control Relay-61311367391
            Headlight spray nozzles x2-61671369124
            Plastic T x3-61661355939
            One way valve for headlight spray nozzles x2-61661380464
            T valve for nozzles on hood x2-61661374978
            Intensive Wash Wiper switch-61311372583
            Flat Lens Euro lights with holes in mounting buckets for Wipers
            Lots of Washer fluid line
            That is a quick and dirty parts list, In total I spent around $300 for everything, but purchased around $140 worth of stuff brand new at the dealer, like plugs, fittings, washer tank etc......
            • mikeedler
              • 6707
              WOW!! $300 for some water to squirt on your headlights! to each thier own, but Im sure it looks cool, especially in the states where no one else has it.
              • Bimmerfanatik
                • May 2004
                • 5349
                Bingo. To each his own.
                After I get everything else settled on my euro car (exterior, interior, M50 build, etc.) this will be something I'll add. Total bling and overpriced, but after I get everything else done, what else can I spend the money on?
                PS - someone will try to tell me to spend it on autox or something - don't worry, I've got my track car for that :)
                Congrats and post pics or ban. :)
                • rs4pro3
                  • 5808
                  I will have pics in a week or so. $300 is cheap considering that setup on ebay went for ~$400 and the relay and harness alone at the dealer new are $200
                  • redbull 325is
                    • 7471
                    i only have 2... front window.... and REAR window. hehee
                    julien
                    91 324td touring
                    Build Threads:
                    • rs4pro3
                      • 5808
                      I bet that rear window must be fun to plumb.
                      • Digitalwave
                        is a poseur
                        • 6292
                        I'm sure it came that way from the factory.
                        RISING EDGE
                        • rs4pro3
                          • 5808
                          Ya but if you had to redo it ever.
                          • ColdAccord
                            • 5926
                            one of my lines bbusted and sprayed washer fluid all over the trunk of my touring
                            ah well
                            Originally posted by blunt
                            • rs4pro3
                              • 5808
                              I decided to try my old digi cam again, so here are some crappy pics. I'll post good pics in about a week of everything.
                              Front end
                              Pasenger wiper
                              Driver side wiper
                              Washer tank
                              Car way back in the garage
                              City lights on
                              Lows
                              Lows and Highs
                              Of all the things I like the city lights the best :twisted:
