Help me get e30 started thtas been sitting for 4 years
  • jaydeep
    • Jun 2011
    • 208
    1988 325is is been sitting for 4 years. I did search and with e30tech members help I was able to find out fuel pump was bad. I replace fuel pump and still car does not want to start.
    My guess is that its fuel filter. But before I start replacing all parts I would like to see if fuel is reaching to engine. Which line should I remove and check if fuel is reaching or not?
    BTW if I put fuel from intake line engine runs for bit.
    sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.
  • Cletonius
    • 2809
    Do the fuel system tests in the bentley.
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • Simon S
      • Oct 2004
      • 3758
      and start drinking.
      -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
      • pandaboo911
        • 2070
        Your fuel lines are most likely clogged, flush out the fuel rail, injectors and fuel lines. I would replace any oil seals as well as they are probably cracked..
