Cayman handling vs e30
  • BMC227
    • Apr 2011
    • 448
    #31
    Originally posted by havand
    What would it take for an s50 powered e30 to keep up with a stock cayman during spirited driving?
    Definitely not a US spec BMW lol
    They call me the frog
    - E30 Alpina C2 2.7
    - E30 Alpina C2 2.5
    - E28 M 528I 3.5 (300HP)
    - E36 M3 S50 3.2 (Euro)
    • Wh33lhop
      • 11705
      #32
      Originally posted by Kershaw
      an m42 out accelerating an m50 in a straight line? and just slowly losing to 911s?
      somethings not right.
      M42 in gutted E30: ~2300lbs ~140hp
      M50 in E36: ~3100lbs ~190hp
      It is not that far fetched, and he didn't lift for a lot of corners that a lot of other cars did. If you check 9:20ish you'll see a douchebag in a 964 targa doesn't let him by because he can't catch up down the straightaways.
      Originally posted by Jean
      H&R sports are tooooo soft anyways.
      Way too soft. :(
      paint sucks
      • Fusion
        • Nov 2009
        • 3659
        #33
        Make him nervous, he'll spin out sooner or later.
        • havand
          • Sep 2004
          • 171
          #34
          Ha. He's my friend! I want to keep up with him, not wreck him. If I was going to go that route why would I work so hard when a pit maneuver is just a quick tap away???
          So the comments here make it seem like a huge feat requiring lots of money. Oh well. I'll just drive my car and enjoy it. Upgrade it as I see fit. I have pondered what it would take to swap in an e36 rear suspension, but I don't have the time, fabricating knowledge and extra garage space a project like that would require.
          • 325ix
            • Aug 2009
            • 7783
            #35
            I have wondered about an e36 rear on an e30 as well. I have no idea what it would take or if it is possible. It would be more cost effective to buy an e36 than swap over the whole rear suspension I would imagine. However, I just don't like the looks of the e36. The Mcoupe suspension is a direct swap, however it is just beefed up e30 stuff. It doesn't have better geometry in order to eliminate the camber and toe change the e30 suffers from.
            • Mike The Bavarian
              • 488
              #36
              there's ways to modify the rear trailing arms to help eliminate that.
              • 325ix
                • Aug 2009
                • 7783
                #37
                I would imagine there is, but I don't know what it is. Can it compare to the e36 suspension?
                • Mike The Bavarian
                  • 488
                  #38
                  they used to do it to the dtm cars. someone did a write up about it on s14
                  *edit* that was before they started using custom arms and ect
                  • Holland
                    • Nov 2008
                    • 7212
                    #39
                    Wasn't that when they changed from the 15 degree trailing arm to the 12 degree trailing arm in the race car and it made a huge difference in the alignment under cornering?
                    Originally posted by DEV0 E30
                    • Mike The Bavarian
                      • 488
                      #40
                      later on they did that. the early dtm car cars used simple and cheap reinforcements.
                      • Mike The Bavarian
                        • 488
                        #41
                        here's the article about the arms. http://e30m3project.com/e30m3perform..._sub/index.htm
                        • Holland
                          • Nov 2008
                          • 7212
                          #42
                          Now those kits are readily available on the market, wouldn't there be a different way to alter the geometry?
                          • Mike The Bavarian
                            • 488
                            #43
                            I'm sure that a body shop could bend the stock arms or something. but the reinforcements that were seen on those arms and cheap and fairly easy to do.
                            • Holland
                              • Nov 2008
                              • 7212
                              #44
                              Makes sense, I would love to see some one make a legit 12 degree setup, but I would imagine it would require some low offset wheels to compensate.
                              • sasha18yug
                                • Jun 2011
                                • 64
                                #45
                                OK here is the deal... i think that you guys are overrating the cayman a bit... for example at the nurburgring the cayman has a best time of : 8,16 ... this guy:
                                http://www.youtube.com/watch?v=CHIlVLmgB2I does it in 8.26 ... and he is no proffesional driver and has about 210 hp... the track is approx 20 km long... i think with more power and the some rubber and some 5000 $ suspension that they use in german hillclimb ... that cayman is gonna eat dust..Just my opinion....:P
