RPM gage is not working
  • jaydeep
    • Jun 2011
    • 208
    In my 325is RPM Gage is not working do you guys know what might be problem? Fuse? Relay?
    sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.
  • flyboyx
    • 8371
    maybe. more likely its the wire with the ring that goes from the spark plug wire.
    Gigitty Gigitty!!!!
    • Asbradley21
      • Jun 2008
      • 1938
      Does the temp one work? It could be the SI batteries.
      S54B32 swap in progress. Status: Getting There
      • Aus E30
        • Jul 2009
        • 478
        Everytime mine goes it's the fuse. Place to start.
        Your signature picture has been removed. Refer to the Signature and Avatar Guidelines in The Rules.
        I <3 dead naked girls.
        • Holland
          • Nov 2008
          • 7212
          Try checking the tachometer, if problem persists use Bentley.
          Originally posted by DEV0 E30
          • Pantless Spency
            It's McRib time!!!
            • Feb 2011
            • 7283
            give it a good smack.
            mine didn't work when i got it and randomly started working out of no where.
            • 325ix
              • Aug 2009
              • 7783
              That causes mine to work, I think it may be a lose wire on the back.
              • jaydeep
                • Jun 2011
                • 208
                Temp Gage is not working. Fuel is working.
                • jaydeep
                  • Jun 2011
                  • 208
                  Guys Temp, RPM & MPG gages are not working. Speedometer and fuel gages are working.
                  Checked fuses
                  How can you tell if its SI battery?
                  • 87e30
                    • Jul 2008
                    • 5676
                    Our SI boards like to go crazy.
                    I don't think there is a definitive way of knowing, but my bet would be on SI shtuffs.
                    I just hate everyone.
                    No need for discretion.
                    • wannaBMthree
                      • Apr 2007
                      • 601
                      Same happened to me, it was a short, the wire that went by the transmission / gear shift lever. I clipped it and my gauges and everything worked. Of course now I have no reverse lights. :)
                      • MonkeyMan
                        • Jul 2011
                        • 426
                        I have the same problem, but only intermittently (when I park it in the sun for a few hours)... and then it starts jumping around a little bit before it starts to work again (something cooled down?)
                        I see the tach signal wire on the ignition wire, which is connected and in good shape, now what is this SI board you're talking about?
                        Make the bastard chase you.
                        • mkcman17
                          • Jul 2010
                          • 8240
                          usually swapping the plug or tach fixes the problem for me.
                          1989 LN106 Hilux / 3.0TD SFA
                          1974 2002tii / stock
                          2002 IS300 / 5spd LSD
                          • e34john
                            • Apr 2006
                            • 3599
                            si board or its batteries
                            • MG325i
                              • Jan 2007
                              • 805
                              what is this you speak of? my rpm gauge doesnt work with my 318is. i swapped my speedometer into a friend of mine, and the rpm gauge works. swap it back, doesnt work.
                              E30 325I > SOLD
                              E30 318IS > SOLD
                              E39 530I > SOLD
                              EP3 > SOLD
                              95 M3 > SOLD
                              97 M3 > DD
