Broken down frankfurt
  • delfin
    • Nov 2007
    • 1064
    Hey so my car decided it doesn't want to start. It is turning over but not catching. What do?
    Advanded Delphin Division
    My e30s: 1987 325i/1994 318iT
  • Fusion
    • Nov 2009
    • 3659
    Take the back seat out and bang the fuel pump. Sometimes you don't have to take it out, just hit it on top.
    If that does help, don't turn the engine off until you get home.
    Second option - hardwire the fuel pump relay. I can't remember if it was # 85 to 86, someone will correct me.
    • delfin
      • Nov 2007
      • 1064
      Thanks man, I'll try it in the morning. I ended up walking to a place to stay for the night. Hopefully it works... It's a wagon, if that makes a difference.
      • Fusion
        • Nov 2009
        • 3659
        I take it you're a soldier in De?
        If all else fails, post up on http://www.bmw-syndikat.de/bmwsyndikatforum/, I'm sure someone local will be glad to help you out.
        • Jesse30
          • Jan 2007
          • 3936
          or check your CPS
          • delfin
            • Nov 2007
            • 1064
            Air force out of ramstein. I might have to check out that forum if it's not the fuel pump.
            • brutus87
              • 6280
              CPS!
              CPS!
              thats what happened to mine.
              The CPS plug was simply loose.
              • delfin
                • Nov 2007
                • 1064
                Ok stupid question: what is a cps?
                • delfin
                  • Nov 2007
                  • 1064
                  Ok after a little searching I see that I have had all the problems to indicate a faulty cps. ie bad idle, random power loss, random.shaking. Where is it on the e30 and how hard is it to replace?
                  • hotballs
                    • 1155
                    On the lower front of the engine. It reads off the toothed crank pulley. Sometimes that wire frays at the base and breaks off. Also happened in my e36. Died on the highway out of no where one day.
                    • delfin
                      • Nov 2007
                      • 1064
                      Awesome. Hopefully I can get to it without tools. Fml.
                      • hotballs
                        • 1155
                        Well after removing some coolant hoses you'll need a 3/4 mm hex key to remove it.
                        • delfin
                          • Nov 2007
                          • 1064
                          I'm not even seeing it at this point. No idea what I'm looking for.
                          • delfin
                            • Nov 2007
                            • 1064
                            Fuel pump isn't buzzing. That's probably the problem.
                            • delfin
                              • Nov 2007
                              • 1064
                              They quoted me 215 euro for a new fuel pump, so I learned real quick where the auto recycling center and pulled one for 10 usd. Hope it works.
