Anyone know where to find pre-made plastic discs?
  • Jand3rson
    • 37587
    I'm working on an idea for some new centercap emblems for my wheels, and I'm trying to find a source for pre-made plastic discs, 77 - 77mm in diameter. They wouldn't need to be any more than about 1/16 - 1/8" thick, and I'd only need 4 of them, 8 if possible to have spares.
    Does anyone know of a place where I can get something like this from? The only thing I can find around here is a plastics supply place, and he said he'd have to have them laser cut at a final cost of about $30 for 4 of them.
  • Gobig_us
    • Jul 2008
    • 148
    What kind of plastic are you looking to get? ABS? Polycarbonate?
    • Jand3rson
      • 37587
      Honestly, it really doesn't matter. I just want something will be paintable, then apply vinyl decals to and clearcoat.
      I can't find what I want for my wheels, so I'm making them.
      • Mlarsen
        • 4082
        Whats wrong with that?
        • blueapplesoda
          • Dec 2005
          • 1904
          use polycarbonate and This and you can make whatever/however many discs you need
          • Jand3rson
            • 37587
            $30 to have them cut. After paying about $10 for the material. Don't you think if they're available somewhere, they'd probably be a little cheaper than $10 each? Especially if I'd like to have 8 of them?
            And that adjustable hole saw won't work, I can't have a hole in the center. They need to be just flat, solid discs.
            • george graves
              • 19996
              Hmmmm. I'd say you'll have to get creative. Maybe find some cheap ebay caps and then apply your decal to that?
              The other option is to find a local hackerspace, and see if someone there is interested in doing the work.
              Originally posted by Matt-B
              • svn2002s
                • Sep 2004
                • 479
                Do you have a router? Check youtube for tricks.
                • MarshallM
                  • Feb 2007
                  • 229
                  If its only 8 and a custom one time thing just fill the holes.
                  • Stevie30
                    • Apr 2007
                    • 1534
                    Josh,
                    Check the plumbing aisle at Lowe's or Home Depot if you have them where you live. I use a plastic test plug to make centers for my AC Schnitzer wheels. The ones I use are 52mm Dia.
                    The following is some info I sent to a fellow member recently.
                    I hope this helps you out.
                    UPDATE!!!!!
                    The most recent ones I made were slightly different. The basic plug is the same except painted silver to match the wheels. Then I had the AC Schnitzer logo printed on clear vinyl and cut them out and applied. They are about $35 for a minimum of 20 logos. They came out perfectly. Here's a picture:
                    Again, good luck and send pictures when you finish the project.
                    Steve L.[/quote]
                    1991 325ic and 1991 318is
