Failed smog
  • june3o
    • Apr 2011
    • 90
    Failed smog
    I have a 91 318iS, went to smog my car and failed... Specifically failed at 15mph test. my HC and NOX are high. Passed my 25mph test without problems. Can someone explain why? Thanks!
  • Dj Buttchug
    • Jun 2010
    • 7688
    let the car sit to long before test? if so cat was cold and wasnt working properly.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • june3o
      • Apr 2011
      • 90
      You think so..
      • SoEm0
        • 449
        with both Nox and HC high I am pretty sure it was a cat issue. Get that bad boy seriously hot and get it on the machine while it is hot.
        CCW- when every second counts... The police are just minutes away!
        • phreshkid
          • 4655
          Don't put alcohol in your gas tank before the smog: it raises NOx. Change your oil, spark plugs, put in good gas, and run around for a day or two and seriously drive the car really hard before the smog. If you has a wait time before you can getyour car smogged, drive around more. Get that cat hot as feck.
          • june3o
            • Apr 2011
            • 90
            Well I guess that being said.. I really need to get my cat really hot... Fresh spark plugs just 3 weeks ago, she gets 91 octane. But I need to change oil.. Thanks a lot yo!! Im gonna try again next week..
            • bmwguy325is
              • May 2011
              • 1263
              Ya my car didnt pass smog either. The guy didnt buy that me resonator was my cat.
              I do however agree with the above get it hot. OR Buy the dude lunch and maybe you get a freebe
              sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
              The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
