favorite tire pressure gauge
  • davem
    • Jun 2010
    • 705
    I've noticed that all my "cheapo" tire gauges give different readings. Which ones do you guys like?
    What about this one?
    http://www.pelicanparts.com/cgi-bin/...essure%20Gauge
  • b*saint
    • 3794
    I bought a simple one from parker pneumatics. How exact do you really need to be with tires?? +- 2 psi is going to make a difference on cars. My bike I try to use a nice one.
    Ma che cazzo state dicendo? :|
    • Sailor37
      • 985
      I use one like this...think it's kinda handy.
      I slightly overshoot my intended pressure and use the bleed valve to adjust.
      • 5Toes
        • 9836
        My free Tire Rack digital one I got for free from Street Survival
        • 5Toes
          • 9836
          But more importantly, what pressures do you guys run? I have 34 +-1 all around adn tires seem to be sagging a little
          • davem
            • Jun 2010
            • 705
            I shoot for 29 front 32 rear because that's what the owner's manual says. Apparently my gauge is inaccurate and I'm actually running 32 front 35 rear.
            • der affe
              Technical
              • Dec 2005
              • 8452
              you need to see what your tyres are rated at for inflation.
              running a 55-60 psi max tyre at 32 lbs is not doing it any favors.
              • Cinnabar325is
                • 1064
                I have this one from Pegasus: http://www.pegasusautoracing.com/pro....asp?RecID=337
                I love it. It reads exactly the same as an old expensive German-made TP gauge that my dad bought back in the '70s.
                As opposed to a few other gauges we have, two being Accugauge (which read about 2lbs different than each other).
                '89 BMW 325is Zinnoberrot / '88 VW Jetta GLI 16v Tornado Red / '89 VW Jetta GLI 16v Tornado Red / '89 VW GTI 16v Bright Blue Metallic / '91 BMW 325i Black / '91 BMW 325i Sport Black / '92 VW GTI 16v Black / '92 VW GTI 16v Montana Green / '01 Audi A4 Avant TQM Silver Metallic / '01 VW Jetta GLX VR6 Black
                • Raxe
                  • 5346
                  Got a couple of these bad boys, definitely my favorite.
                  • JeST
                    • 639
                    snap-on tire gauge and air chuck
                    Current: 1988 M3 - Henna/Black black alcantara
                    Guten Parts + Service
                    ... When you care enough to only give the very best.
                    Previous:
                    '87 S50 MTech 1 325is
                    '07 DTM Audi S4
                    '03 VF Supercharged M3
                    '03 Lexus IS300 (615rwhp/512rwtq)
                    • acolella76
                      • 2950
                      I like the ones that look like a tire. That way if I'm checking my tire pressure and I forget what I'm checking, it reminds me.
                      -Alex
                      • Eecen
                        • Jun 2010
                        • 1235
                        • davem
                          • Jun 2010
                          • 705
                          How do I find this info? Falken 512... so should I be running higher psi?
                          • der affe
                            Technical
                            • Dec 2005
                            • 8452
                            Look on the side of the three, it will say max load xxxxxx max pressure.
                            I alway run within 5-8 lbs of the max depending on the season ( silly hot here in the summer) you need to account for three expansion from heat which will raise your pressures . You can run more in colder weather or climates.
                            I have never had a problem with uneven tyre wear because of this either.
                            • acolella76
                              • 2950
                              I alway run within 5-86 lbs pf the max depending on the season ( silly hot here in the summer) you need to account for three expansion from heat which will raise your pressures . You can run more in colder weather or climates.
                              I have never had a problem with uneven three wear because of this either.
                              idk about that, 86lbs over what's suggested seems a bit overkill.
                              :p I know what you mean, i do the same thing.
                              -Alex
