Rebuild it Right (engine building) by GRM
  • deutschman
    • May 2008
    • 5958
    Who reads GRM?
    If you are thinking of, or even have built an engine, you should read this GRM article! It is what you need to know, or what you wished you knew, before building your first engine.
    http://grassrootsmotorsports.com/art...uild-it-right/
    Thought I would share this.
    Cheers!
  • bimmerboy08
    • Apr 2009
    • 353
    Thanks! I was thinking of rebuilding my spare m20 when i get home from this deployment, and this will be a good read.
    • deutschman
      • May 2008
      • 5958
      Do lots of reading! I just finished an m20.
      It is a job that requires a careful eye for detail and a strong ability to follow directions. Rebuilding an engine may not be hard work, but it is precise work. Every part that goes into your engine has to be mated squarely with the others. The clearances will be less than a few thousandths of an inch, so there isn’t much room for sloppiness or shortcuts.
      This!!! ^
      Take your time!!!! Plan ahead. Try and get second opinions (professional, machinists) on everything that goes in your motor! There were a few parts I bought that looked OK to me but turned out to be crap when checked by Tim at Morgans Speed Shop.
      • Dj Buttchug
        • Jun 2010
        • 7677
        a good amount of r3vers need to read this... enough said
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • trackjunkie21
          • Jan 2010
          • 3962
          troof
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
          • acolella76
            • 2950
            This is a good read. When I disassemble and rebuild an engine, I am so fucking OCD it's insane. Every set of bolts in a ziploc bag, labeled, organized, etc. Which is hilarious because my bedroom hasn't been cleaned since 2006.
            -Alex
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              ^That's not OCD, that's doing it the right way. If your whole life were organized, then it might be OCD.
              • deutschman
                • May 2008
                • 5958
                Thats what I like to call OCDC. It's like OCD just a lot cooler!
