do e30 instrument clusters fit any type of e30 or do the connection points at the back change through the years or other components etc
instrument cluster compatibility
eta's have coding plugs that will limit your engine to 5k rpm. really early e30's like the 84-85's didn't have coding plugs. vdo and motometer are interchangeable. hope this helps.sigpic
Gigitty Gigitty!!!!
Originally posted by flyboyx View Posteta's have coding plugs that will limit your engine to 5k rpm. really early e30's like the 84-85's didn't have coding plugs. vdo and motometer are interchangeable. hope this helps.91 318is M50 swapped
05 Honda Pilot
24V swap thread
Originally posted by mikeedler View Postplugs are on the right front corner, white in color. early clusters have them in the rear directly in the tachsigpic
- 1987 325e m20 6cyl manual -
Get a cluster from the same or close year and model for best compatibility.
Otherwise you may need to swap the fuel gauge and coding plug.
early clusters also had coding plugs, but they are different from the late model cars.
early clusters also have crappy si boards as well.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by DrJosh View PostFor some reason a late model speedo out of a vert runs 10mph fast in my 325is.
Originally posted by vladDo you know anybody else who built that many bad ass E30s?
