understeer?
  • kcoelhoe30
    • Jun 2011
    • 219
    understeer?
    im not to good with suspension stuff so here it goes.
    What can i do to help "eliminate" understeer
  • Joe G
    • 2942
    turn in softer.
    Current Car: 2011 BMW 135i, M-Sport, 6 speed
    Originally posted by lambo
    Sounds like you need a massage.
    Originally posted by kpeng
    Who the hell is Vlad?
    • Dj Buttchug
      • Jun 2010
      • 7672
      steer with the gas pedal
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      • kcoelhoe30
        • Jun 2011
        • 219
        lmao im lovin this but umm should i tighten my suspension? soften it? moar sway bar?
        • acolella76
          • 2950
          it has little to do with the suspension
          -Alex
          • Dj Buttchug
            • Jun 2010
            • 7672
            softer front tire pressure
            Ig:ryno_pzk
            • acolella76
              • 2950
              OP, can you actually give an example of when you felt like there was too much understeer?
              -Alex
              • LivingLegend06
                • Dec 2006
                • 1604
                reverse tire stagger.
                • Dj Buttchug
                  • Jun 2010
                  • 7672
                  clutchkick
                  Ig:ryno_pzk
                  • A.J.
                    • 95
                    Quit driving into turns too fast. Do most of your braking in a straight line...slow(ish) in to corner...fast out. Or get a Honda Accord that plows so much you'll think the e30 doesn't understeer at all.
                    • kcoelhoe30
                      • Jun 2011
                      • 219
                      the last comment answred my problems im just a failed driver i guess
                      • kcoelhoe30
                        • Jun 2011
                        • 219
                        thanks for the help guys
                        • ACHTUNG
                          • May 2005
                          • 2397
                          Brake with the left foot
                          1989 US E30 Cammed S52
                          Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                            • 37829
                            Drive in reverse.
                            Classic BMW Specialists
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • gverelli
                              • Dec 2008
                              • 772
                              Originally posted by Joe G
                              turn in softer.
                              Start with tire pressures, I eliminated 95% of my understeer by lowering front tire pressure and being smoother on turn in. What suspension modifications do you have? It will be a trial an error kind thing because everyones cars are probably set up differently
                              G.Verelli
