Your take on rising rate fuel pressure regulators
  • jaywood
    • Jul 2010
    • 4528
    What's your take on RRFPR's?
  • Dj Buttchug
    • Jun 2010
    • 7678
    its a cheap way to slam more fuel through injectors that are too small.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • jaywood
      • Jul 2010
      • 4528
      Agreed. Do I need one?
      T3 turbo. Chip. Wideband. ~8lbs boost. 30lb injectors. M20.
      • Dj Buttchug
        • Jun 2010
        • 7678
        mmm you may be able to get away with stock fuel pressure because of the bigger injectors.
        maybe someone with rrfpr experience can chime in. might want to consider a better fuel pump as well... tre 255
        Ig:ryno_pzk
        • trackjunkie21
          • Jan 2010
          • 3962
          I'd go on M42 club and contact one member who only works with rrfpr's, he is really good and makes special chips for them aswell
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
          • jaywood
            • Jul 2010
            • 4528
            That's kinda what I was thinking too. I know the injectors are big enough for my power goals.
            • Dj Buttchug
              • Jun 2010
              • 7678
              run stock stock fpr and rail with the green tops and tre 255lph fuel pump and youll be fine.
              Ig:ryno_pzk
              • trackjunkie21
                • Jan 2010
                • 3962
                Lol and run pig rich at everything other than full throttle? That isn't very smart at all.
                • Dj Buttchug
                  • Jun 2010
                  • 7678
                  not if he chips it...
                  Ig:ryno_pzk
                  • trackjunkie21
                    • Jan 2010
                    • 3962
                    Guess I missed that part.
                    • Dj Buttchug
                      • Jun 2010
                      • 7678
                      but ya truth stock motronic with 30lb injectors sucks a fatty. it almost doesnt even run.
                      Ig:ryno_pzk
                      • jaywood
                        • Jul 2010
                        • 4528
                        Stock motronic can handle 30lbers
                        • browntown
                          • Jun 2004
                          • 3524
                          So this is rather tangential, but apparently it makes it harder to tune megasquirt with rrfpr. The consensus seems to be to get an adjustable, but tune around a specific rate.
                          • Jaxx_
                            • Dec 2009
                            • 1880
                            bandaid. But if you want to go ghetto, that's the way to do it. Just don't go higher than 60psi. And if you're going turbo I would suggest something like SAFC. Still, you're not going to make proper power unless you have a good spark map.
                            I think that 30# injectors will be fine for 8psi but you should have a way to tune for that fuel.
                            • Dj Buttchug
                              • Jun 2010
                              • 7678
                              yea but without a rom tune or chip it runs like shit. ask me how i know.
                              Ig:ryno_pzk
