FML my car is bleeding
  • ohthejosh
    • 4963
    bleeding coolant :(
    I was on my way to my gfs place before going home last night and my car starts to smoke up and overheat. Luckily I made it there with out breaking down but the engine did stutter and stall when I was parallel parking. Long story short I checked the coolant tank saw it was empty, tried to fill the tank, found a massive puddle of coolant. Drove it home and now here I am.
    At this point I have no clue exactly where it was but looks to be the hose from the tank to the engine is where the leak is. Hoping its just the hose and nothing major. Wish me luck :(
    SO MUCH MORE TO DO!!
    IG: ohthejosh
    LEGIT CHECK ME BRUH
    BUYER FEEDBACK THREAD
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    you have the opportunity of a lifetime!
    my car was overheating when i got it, all it needed was a thermostat, but i realized that too late after i blew the HG.
    don't take any chances fix whatever it is now, you will regret it if you dont.
    • Zasz
      • 1030
      For me, it was just the hose that went, no damage to anything else. The scariest thing was when I found out, the bottom of my car had a cloud of steam hovering under it. Good luck.
      ///Z
      1988 BMW 325 Super Eta - Elsa
      "i"CONVERSIONWARchip&3.0MAF3.73LSDBBSRSsSMILIES"is"SPOILER+LIPHOUNDSTOOTHSHORTSHIFTERPLASTICBUMPERCONVERSIONEtc.
      Sell Me Your SCHWARZ FENDERS!
      ^ Nothing you post makes any sense.
      • kingston
        • Jun 2010
        • 2669
        Good luck man! Might want to replace ALL your hoses at this point. Better to do it now, then have to deal with another one blowing out while you're driving.
        If one's old and tired, chances are they ALL are...
        Originally posted by LJ851
        kingston is the play by play announcer for this thread.
        ‘Tis by the grace of God that my cars run!
        Originally posted by unloadedak
        #teamross
        Siobhan's Build Thread - UPDATED!
        • F34R
          sLaughter
          • 12376
          Once a week I do a complete bay detail etc. That keeps everything clean and checked over. I used to detail mine for car shows and it helped me find loose grounds and cracking vacuum lines.
          So my advice is to spend more time with your engine.
          Instagram: @BWeissLeather
          Current cars:
          ~ '87 325 M30B35 swap
          ~ '87 535
          ~ 01 540 Msport 6spd
          ~ '06 X5 4.8is
          • ohthejosh
            • 4963
            Yea with my finances I cant afford HG issues. But I think I am okay right now. Definitely not driving the e30 as a dd anymore. Luckily I have a my e90 and f10 to fall back on.
            IG: ohthejosh
            LEGIT CHECK ME BRUH
            • ohthejosh
              • 4963
              Yea the whole reason I cleaned out my garage was to due major engine maintenance. I know I have to replace my oil pan gasket too. Major gunk on the underside. This will help me get some experience and mechanical know how. I'm sad but happy.
              IG: ohthejosh
              LEGIT CHECK ME BRUH
              • Dj Buttchug
                • Jun 2010
                • 7667
                you drove it to far... it got to hot. hg is sploded?
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • ohthejosh
                  • 4963
                  no sploding. :)
                  I'm 90% sure its just a hose, but I shall see when I do a tear down.
                  IG: ohthejosh
                  LEGIT CHECK ME BRUH
                  • Mercury[BKM]
                    • Apr 2011
                    • 909
                    your girlfriend did it... she hates your car
                    I can run Auto Checks on VINs for tips/donations:
                    PM me VIN(s) and I'll get you ALL the public recorded info that I have available.
                    paypal as gift to Mike@benzinkrieg.com
                    Information/Request sticky thread for Vehicle History Reports
                    http://www.r3vlimited.com/board/showthread.php?t=216119
                    • ohthejosh
                      • 4963
                      maybe just maybe lol
                      IG: ohthejosh
                      LEGIT CHECK ME BRUH
                      • ohthejosh
                        • 4963
                        Okay i thought about it and since I'm going to have to replace something I might as well replace everything. So can somebody give me input and a list of exactly what i should replace and where I can get most of the parts.
                        Also since I don't exactly have the money to do an s52 swap like I want, I was thinking of doing a 2.7i conversion. What parts do I need to make my eta into a 2.7i. Is it even worth it to do?
                        IG: ohthejosh
                        LEGIT CHECK ME BRUH
                        • nebulous123
                          • Jun 2011
                          • 923
                          11-53-1-279-895 - Water Hose, Radiator/Lower
                          11-53-1-286-914 - Water Hose, Radiator/Upper
                          11-53-1-287-651 - Water Hose, WP to Thermostat Housing
                          11-53-1-289-257 - Water Hose, Expansion Tank
                          11-53-1-466-174-71 - Thermostat, 71 Degree (Change end of part number for different temp)
                          PEL-SW50189 - Redline Water Wetter, 12 oz. bottle
                          [1] Gallon - Prestone Lime Green Coolant
                          [1] Gallon - Distilled Water
                          If you want to be picky:
                          17-11-1-707-540 - Coolant Expansion Tank (cap not included), Plastic
                          61-31-1-375-715 - Expansion Tank Coolant Level Sender
                          11-53-1-275-881 - Bleeder Screw in Thermostat Housing
                          [8] Hose Clamps - All Genuine BMW (various sizes)
                          EDIT: Above is just for coolant replacement. 2.7i engine good luck.
                          '84 325e - "Elizabeth"
                          '87 325e (SHELL) - "Sleeping Beauty" - COMPLETE PROJECT PART-OUT - S54, 5-LUG, and MORE
                          • Eecen
                            • Jun 2010
                            • 1235
                            How high did your temp get?
                            Do a comp. test...if you ran the coolant dry chances are you were in the red.
                            • ohthejosh
                              • 4963
                              Awesome this is exactly what I need. If someone could also help me figure out what I need just to do a stock replacement.
                              It did go in the red when I stopped for the night but the next morning I tried filling the tank with coolant and drove about 10 miles just fine without overheating. I can't do a comp test because I made it to my house but i really can't go any further so I think I might as well just do the entire engine maintenance at this point in my garage.
                              And my car does have over 300k miles.
                              IG: ohthejosh
                              LEGIT CHECK ME BRUH
