M3 firewall harness/cover re:m20 diagnostic port and relays
  • iwantspeed
    • 3164
    Just went through 70 pages in the member rides engine bay thread and around 40 pages in the 24v swap sub folder.
    Couldn't really find anyone who has a m20 with the diagnostic connector relocated on the end of the m3 firewall harness cover next to the fuse box.
    And the relays relocated to the inside of the m3 cover
    I assume this is because on a late Model( possibly early ) the wiring harness for the diagnostic connector also includes the wiring for the crank position sensor and impulse sensor wire. Those 3 items are wrapped in a wire sheath And end up right underneath the intake manifold.
    Same problem for the wiring loom going to the 3 relays in front of the shock tower. The afm wiring and the 3 relay wiring are both in the same loom.
    I have my c 101 connector inside the cover.
    Could I just cut the sheath around the wires and relocate the relays and diagnostic connector to the m3 cover and just retape the harness?
    Stock e30 m3's and 318is's have it setup like this.
    How I set mine up. (work in progress)
    And Simon's beauty. This how his came stock
    This is what I'm after but on an m20.
    Project
    Parts for Sale
    Feedback
    YouTube Channel
  • glucklich21
    • 1912
    Get a 318i blower motor cover panel and it bolts up directly. Then it's just a matter of relocating everything to the new cover.
    • iwantspeed
      • 3164
      Thats not the issue im asking about.
      Project
      Parts for Sale
      Feedback
      YouTube Channel
      • e30rapidic
        • 2167
        You can just cut the sheath and add/remove wire length to put stuff where ever you want it. Here's a picture of my S50 and relocated diagnostic port. I did all the wiring myself....and the main relays are under the wiring cover.
        even though its not an M20, gives you an idea what it looks like. I used the bracket that was already there.
        '87 325ic, powered by S50.
        • mikeedler
          • 6707
          I put the relays under there, but it just seemed like too much worthless work to set the diag. plug there too. had to make the afm wires a bit longer to go back to it, and actually cut the diag. plug bracket off the M3 bracket.
          • iwantspeed
            • 3164
            I took the entire engine harness out, split the harnesses and mounted the relays and diagnostic port. Now I can cut the wires and re splice them in
            Wrap the rest of the harness and reinstall it.
            Project
            Parts for Sale
            Feedback
            YouTube Channel
            • iwantspeed
              • 3164
              Got it done.
              I bought the firewall bracket new and apexgoblin hooked me up with the large cover section used but for free I used it for mock up. Going to order the battery tray and firewall cover section new from the dealer.
              Project
              Parts for Sale
              Feedback
              YouTube Channel
              • e30rapidic
                • 2167
                looks good!
                • BelaRaian
                  • Sep 2011
                  • 1
                  Very good. Keep up your good work.
                  artificial grass supplier
                  • kid325e
                    • Sep 2007
                    • 6421
                    Looks great! Keep up the awesome work, my only comment is keep in mind those zip ties will chaff if they're on too tight. Maybe use something with less of a sharp edge to keep everything tidy? To be honest I don't know if that's going to be an issue, just something I thought i'd mention.
                    clutchCTRL!
                    Move with a purpose.
                    - 1991 325iX 4dr/5spd
                    - 2000 323i AT
                    2016 Mazda CX3 Sport AWD
                    • freeride53
                      • 11972
                      crafty
                      1983 Peugeot 505 STI
                      1992 Volvo 240 Wagon
                      • iwantspeed
                        • 3164
                        Originally posted by e30rapidic
                        looks good!
                        Thanks
                        thanks
                        I was worried if I rewrapped it that the front cover would not clip on.
                        When I install it I will wrap it then put new zipties.
                        crafty
                        Thanks.
                        Project
                        Parts for Sale
                        Feedback
                        YouTube Channel
                        • browntown
                          • Jun 2004
                          • 3524
                          Just found this, hoping I can do something similar with a m30 swap. Do you have a part # for the firewall bracket, is it off a m42 car?
                          Since you put this much work in the rear wiring, I suspect a 318i radiator (ditch the overflow tank) and moving the coil are in order next.
                          • iwantspeed
                            • 3164
                            yep maybe in the future.
                            i do like that look.
                            Project
                            Parts for Sale
                            Feedback
                            YouTube Channel
                              • 37828
                              Great thread, I was just thinking about this today. Want to do the same with my turbo car.
                              I think I'll email BMA with an order now.
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
