How to?
  • miichaelsmith
    • Aug 2011
    • 300
    How to?
    I just got a new steering wheel. How do I take the old one out and install the new one?
  • Charley
    • 396
    Air bag or no air bag? If you don't have an air bag wheel, just pop the bmw logo using a small flat head screw driver(carefully) them use a 19 or a 22mm(can't remember which one) to unscrew the wheel keep the keys out
    of the ingnition to do so (the wheel will be locked) then unlock the wheel
    using the keys. Then just take it off. If it has never been swapped it may
    take a little persuasion to come off. But be careful not to rip out the horn
    wire when you pull off the wheel.
    Charley
    • Conki
      • 1254
      22mm i believe
      1992 BMW 525iT Calypso
      2011 Jeep Wrangler
      • Schneller 3er
        • Oct 2004
        • 1720
        Air bag steering wheel:
        Disconnect the battery and wait 5 min
        Then there are two torx on the backside of the wheel (don't remember the size).
        Take those off and the airbag should pop off.
        Disconnect the airbag and unbolt the wheel itself (22 mm socket).
        Turn the key to disengage the wheel lock and pop it off
        Non-airbag:
        Pop the center roundel emblem off
        Unbolt the wheel itself (22 mm socket).
        Danny
        88 ///M3 - Zinno street/shop queen
        88 ///M3 - Henna Track rat (Sold)
        98 ///M3 hellrot - Sold
        89 Porsche 944 - dd
        95 E34 525it/pick up - P/U Project
        90 325is - track rat
        • miichaelsmith
          • Aug 2011
          • 300
          Do I have to do anything with the horn or anything?
          • nomansland92
            • 1657
            Make sure you have your wheel straight before you take it off so when you put the new on in the same position, or just mark the splines or something.
            Atleast with a non air bag, you shouldn't have to, just make sure nothing is getting cought as you take it off. There weren't any wires on mine, just a pressure type connection for the horn.
            IX being restored here
            Ix turbo build here
