Which one to use? PICS?
  • new2bmw
    • Oct 2006
    • 387
    I need to remove some surface rust from my floor pans and need something that won't disintegrate too quickly. I have used the nylon wire wheels before and they last quite a while but i saw a 3M rust and paint stripping wheel, it is black and really rough and attaches to your drill also and can be bought as a single wheel or double thick. it is cheaper then the nylon wheels so I am just wondering if anybody has used the 3M one and the nylon ones and which is better. Thanks for your input, just want to get it done fast and to buy the best one.
    thanks everyone.
    Nylon wheel
    3M wheel
    Also, i have a grinder with cut off wheel to get rid of nasty rust, do they make anything smaller, other then a dremel, that has a cut off type wheel and isnt run off a compressor, so i can do more precise work?
  • GunMetalGrey
    • Dec 2010
    • 1499
    I always used the 3m style one, works fine and actually isnt that harsh if you are careful
    • AndrewBird
      The Mad Scientist
      • 11898
      These work very well for removing paint/rust:
      http://www.harborfreight.com/4-1-2-h...eel-94017.html
      And these work great for cutting metal:
      http://www.harborfreight.com/pack-of...scs-66394.html
      I use both with one of these:
      http://www.harborfreight.com/power-t...der-91223.html
      • Nick_S
        • Apr 2011
        • 3658
        I've always usd a wire wheel on my drill for removed rust. Never tried the nylon and if it's just surface rust would probably work fine.
        91 318is M50 swapped
        05 Honda Pilot
        24V swap thread
