Did anyone used BMW OBDII Round Adapter?
  • jaydeep
    • Jun 2011
    • 208
    I have 1988 325is and stop test is not working. I thought its because of TPS but its not TPS I tested.
    Anyway did any one used BMW OBDII round adapter? Does it works? Instead of buying $100 Peake code reader I want to buy $20 adapter if its works with autozone ODBII.
    Here is the pic
    sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.
  • MattM
    • Apr 2009
    • 931
    your car isnt obd2....
    the stomp test should work, does your cel light come on when you first turn the key to run?
    Full Build Thread Here
    • mikeedler
      • 6707
      yes, that connector will work. Euro model E30s have no check engine light, so a stomp test will not work. We read out the codes through a tester and that adapter.
      I have no idea what an autozone OBD II is, but an OBD II tester will work on an E30 with that adapter. Up until 2002 you need that adapter for all euro BMW cars
      • cabriodster87
        • Jan 2011
        • 1042
        Maybe this will help. Autozone reader/analyzer doesn't have ability to read info from BMW adapter. I have asked already, its for Euro cars only.
        Reich und Roll!
        • jaydeep
          • Jun 2011
          • 208
          Is there any one here used this adapter with Autozone reader?
          • bimmer630
            • 1230
            I dont think the OBD 2 software will talk to your car, even with the adapter cable. You need an old Modic/Gt1 or a launch, I think.
            • bmwmech1
              • Jun 2010
              • 1075
              This is correct... add to the list a Baum VS scanner, as well. There are probably a few more.
              Garey
