Stupid question, but I searched
  • 5Toes
    • 9836
    I searched, though I was unsure of the name of what I should be searching for.
    I am wondering if it is okay to remove the felt ugly gross stuff under the rear seat? Is this fireproofing material or what? Mine is dirty and gross and I thought about taking it out... but then thought that maybe the fuel pump and its wires, etc. need it to cover them.
    Any thoughts?
  • slammin.e28
    שמע ישראל
    • 12054
    Do people regularly look under your rear seat?
    • shiboujin
      • Feb 2006
      • 2791
      it's sound deadening. Feel free to take it out. It won't do much for or against you imo.
      • Motorsports
        • Feb 2007
        • 2882
        Less weight.
        • 5Toes
          • 9836
          Just sound deadening, okay.
          Slammin.e28.jew guy nobody looks under there, but it is sort of annoying to work with, so I want it out.
          • shiboujin
            • Feb 2006
            • 2791
            Originally posted by Motorsports
            Less weight.
            Removed ALL the sound deadening in the (interior of the) car. Made like 1.5lbs. So wasn't worth the effort IMO.
            • slammin.e28
              שמע ישראל
              • 12054
              :rofl: :rofl:
              I look under there when you're not looking.
              • Joe G
                • 2942
                I took it out and keep it in the trunk so I can lay it down on my seats when I'm getting down with the ladies. It makes a great vaginal fluid absorber, and you can hardly see stains on it.
                Current Car: 2011 BMW 135i, M-Sport, 6 speed
                Originally posted by lambo
                Sounds like you need a massage.
                Originally posted by kpeng
                Who the hell is Vlad?
                • MaksV
                  • 1042
                  Wrong. If you remove all the sound deadening material (back seat and trunk) its about 40lbs. I with I could find my scale picture, but believe me, it fills a whole home depot bucket and is pretty hefty, for what it is.
                  CHEAP REBUILT INJECTORS
                  Need Quality Brakes? BimmerBrakes has it!
                  For anything Else go with BluntTech!
                  • shiboujin
                    • Feb 2006
                    • 2791
                    I was discluding the trunk as "interior".
                    The trunk material isn't sound deadening. It's weight ballast. Depending on your E30, there is more or less back there. For instance, I don't think verts have it. But 318s have about 75# worth of it. Regular 325s have about 35# worth of ballast back there. It's the same reason why the battery is in the trunk stock.
                    • 5Toes
                      • 9836
                      Well I was worried about the seat maybe disturbing the fuel pump wiring, etc.
                      • shiboujin
                        • Feb 2006
                        • 2791
                        all of that is mounted between the tank and the chassis. I can't recall anything that runs in the cabin related to fuel. There are some ABS lines that run under the seats but I highly doubt this will interfere.
                        • Deltron Dirty30
                          • 2436
                          remove sound deadening
                          because racecar
                          Instagram: @jstnlws
                          • LJ851
                            • 7919
                            You got it backwards. 318is has no ballast in the trunk. My 89 325is had the ballast (trunk tar mat) and it was 50lbs. Verts have a BIG chunk of steel where the rear battery would be.
                            Lorin
                            The M30 is God's engine.
                            • shiboujin
                              • Feb 2006
                              • 2791
                              I stand corrected.
