dumbest e30 question ever, but serious.
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    when you guys remove your hood's for extensive engine work, what do you use to mark the placement of the mounting bracket on the hinge or whatever it is?
    ive been told "mark it or you will spend hours trying to get your hood straight"
    but im not sure what to use.
    help a noob out?
  • blefevre
    • Dec 2008
    • 4287
    There was a very noticeable bolt circle in the paint when I removed mine, therefore it marked itself pretty good :)
    - E30, DSM, Golf R, Mazda 3 Skyactiv
    • Philo
      Ich esse kleine Kinder
      • 3334
      I use a pencil.
      -tim
      Originally posted by Jordan
      I like the stance
      • Rennsport
        • 2139
        m106 1990 e30
        e36 daily
        e32 cruiser
        • KenC
          King of Kegstands
          • 14396
          Mines been off center for two years.
          Originally posted by Gruelius
          • scottinAZ
            • Dec 2009
            • 1312
            This, plus I use a scribe to get a good sharp marking of where the washers sit. Yes you remove/scratch the paint a bit, but it is not only nearly impossible to see, but it also provides a better line to work off of than either a pencil or sharpie which can be rubbed/blurred so you can not get a good alignment back again.
            I saved 15% on my Bimmer parts by switching to ...
            • TurboJake
              • 3780
              I take off the whole hood hinge with the hood still attached.
              Never had to spend time aligning my hood. Never been off center either
              Leave Me Transaction Feedback
              • mikeedler
                • 6707
                when you put it back on, leave all the bolts loose, remove the headlight grills, close the hood and get it in the correct place, tighten the 2 bolts you can get to, lift it back up and tighten the rest. its really easy.
                • alB5
                  • 785
                  when you put it back together, open the hinge so that it lays up, then position hood on top of said hinge and bolt on. It's a one man job if you do it like this. When i took off my hood, a white area where it was bolted was left, so it was easy for me.
                  1991 318is -> 2004 R32 -> 2002 Jetta TDI -> 2014 FiST
                  No E30 Club
                  • acolella76
                    • 2950
                    Good idea. Mine has been off-center since I removed it even though I marked where the hinges were.
                    -Alex
                    • Jafxod
                      • May 2011
                      • 1301
                      No. Ive removed and reinstalled my hood a dozen times. But then again Im not perfectionist
                      • bernzpeed
                        • 3917
                        +1 even for trunk lids
                        89 E30 S52
                        Transaction Feedback.
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          An old hot rod trick is to drill an 1/8" hole through the hinge into the hood before you remove it. Then when you put it back on, just use the drill bit as an alignment pin back in the hole and tighten up the bolts.
                          • ohthejosh
                            • 4963
                            just be badass and go hoodless 4ever
                            SO MUCH MORE TO DO!!
                            IG: ohthejosh
                            LEGIT CHECK ME BRUH
                            BUYER FEEDBACK THREAD
                            • Pantless Spency
                              It's McRib time!!!
                              • Feb 2011
                              • 7283
                              ima do this.
